  • Dot Guests: 167
Author Topic: What have you been up to this week  (Read 893903 times)
0 Members and 15 Guests are viewing this topic.
« Reply #150 on: December 18, 2008, 05:30:34 PM »
might as well do a "what ya been up to ..."
Standard CF:
finished wiring up dash - late model dash in mk1, had to repaint windscreen/wiper panel and inner pillars
waiting on transmission so can get drive shaft done before xmas, I have until monday at the very latest - stress
Custom CF:
been working on all the unseen stuff - shifter cable, handbrake lever, brake lines, and things like booster and steering (no power steer). I'm hoping to line tow the van home on monday so can finish the body off over xmas but if I don't get the trans and driveshaft for the other van it's not going to happen :(
Offline waikatostocky
« Reply #151 on: December 18, 2008, 10:02:49 PM »
Busy if you carnt get the custom one towed back i may be able to borrow (or steal) a transporter truck and come up to akld and do it for ya mate no worrys.
Cheers Paddy
be safe out there
Offline Joel Oswald
« Reply #152 on: December 19, 2008, 01:23:33 PM »
What happened Busy with Neil Fraser??? I was getting mucked around in a sence by a bloke at TSL while trying to organise everything. So switched to Neil Fraser.
« Reply #153 on: December 19, 2008, 06:37:24 PM »
Watch out you guys, this is turning into a NZ post. My van was factory fitted from new with Holden 202 , discs Holden diff etc so does not need a cert so when I add something new they are none the wiser. He He.
« Reply #154 on: December 19, 2008, 07:13:38 PM »
waikatostocky, tomorrow is going to be the decider, if it comes back or not. will let you know, cheers
Joel, this is copy from my van sites bitch and moan page
"Just about finished the first van (around the time I found the bent rail), I phoned and made appointments with two engineers, so they could check over what had been done ... The first was a guy by the name of Neil Fraser, his answer phone message kind of insists you are reliable and leave a message ... but is himself is very unreliable, made an appointment with him and he never turned up, never phoned to say so either, a week or so after we was meant to turn up he phoned and said he was in the area ... I told him he was unreliable and would find someone else. The other was a guy called Mark Stokes, this guy is meant to be the guy, but is very unreliable, made an appointment and he never turned up or phoned. Since doing this van, sorting parts etc you talk to a lot of people, apparently Mark Stokes is well known for being unreliable and has a bad name around the car scene. Avoid these guys if you can."
Bas NZ, I got one of them too - aussie assembled 3.3, problem is my papers say jumbo though
« Reply #155 on: December 20, 2008, 05:46:49 PM »
sounds like you guys are havin some dramas..... good luck fellas,
well, now moved in to new home , sorted shed sorta, next break willl fit new MSD ignition and set timing again try to fire the girl up, fit new electric fuel  pump and lines, give the girl a wash and clean .....can't wait!
check out photos in gallery
doofhard
« Reply #156 on: December 21, 2008, 01:58:07 PM »
I went and did some hillbilly shooting.  I'd never shot a gun before, much fun was had.  An old wreck of a car was the target with a couple of bricks on top.  I wasn't too bad a shot either.  I blasted some bricks and fired a 375 Holland and Holland magnum (this one had some serious kick)  And used a rare 303 low mount sniper rifle.
« Reply #157 on: December 21, 2008, 04:13:20 PM »
Jeez Zeek, was there that dang banjo musac playin in the ol background ?
Squel like a pig bouy :D
68holden
« Reply #158 on: December 21, 2008, 08:25:42 PM »
Put a new floor in the van this week cowrie pine flooring out of a federation house.it didnt come up too badly doing the walls and roof tomorrow fitting  2 rows of 3 drop lights in the ceiling before it goes in
Offline strez
« Reply #159 on: December 21, 2008, 08:31:31 PM »
Photos?   :)
