  • Dot Guests: 323
Author Topic: door seals?  (Read 3552 times)
Offline joshua
  • aghh finally on the road
door seals?
« on: July 21, 2014, 05:53:05 PM »
Hey guys anyone know of a way to door seals? Mine are rubbish and I cant find anywhere... Is there a profile from clarks rubber or something similar that might work....?
Offline Brutus
Re: door seals?
« Reply #1 on: July 21, 2014, 06:33:24 PM »
Hi Joshua,
Rare Spares have a complete kit but I would also use a pinch weld rubber on the door frame as well. Ask for some offcuts and try them first. I continued mine over the top of the frame as well. It just needed some right angle sheet metal to be attached at the top so the rubber could continue through, it has made a huge difference especially at 100 km's for noise. I have not checked if they have profiles for the actual doors.
Dave
It's on my to do list!
Offline Brutus
Re: door seals?
« Reply #2 on: July 21, 2014, 07:02:54 PM »
Meant to say try Clark Rubber for the pinch weld for the door frames.
Dave
Offline Tracey
Re: door seals?
« Reply #3 on: July 21, 2014, 07:09:01 PM »
I have some spare weather strip for the outside window edge, to stop water getting in the door.  Though its not cheap $38 meter.  Clark do sell a good pinch weld i think is $18 meter, that works perfect for the inside to lower the wind noise on the highway.
Offline joshua
Re: door seals?
« Reply #4 on: July 22, 2014, 09:04:48 AM »
Awesome dave!!!!!! Thanks so much il give that a crack... Do you just glue it down? Thanks also
Tracy I have that part under control.
Offline Brutus
Re: door seals?
« Reply #5 on: July 22, 2014, 06:22:10 PM »
Have not had to buy a set yet as mine are not too bad. I have only fitted the Clark Rubber pinch weld to the frame but I believe they doe glue on and from memory there were some older posts on this site re door rubbers. Maybe do a search and check those out.
Dave
