  • Dot Guests: 236
Author Topic: trimatic 3 spd convertion to Aussie 4spd M22  (Read 7767 times)
Offline sjsargent
  • probationary
« on: July 14, 2014, 08:30:35 PM »
Hi guys,
Ive got a 202 3spd auto and im having issues with the shifting of gears and Hi revs. Does anyone have advice in regards converting to 4spd? would a Aussie 4spd M22 fit?
cheers,
sam
Re: trimatic 3 spd convertion to Aussie 4spd M22
« Reply #1 on: July 15, 2014, 05:57:26 PM »
do you mean m21....
« Reply #2 on: July 15, 2014, 08:07:39 PM »
Hi Sam Your not going to solve the high revs with a 4 speed you will need a 5 speed overdrive box or change the diff ratio Plenty off info in the forum section Cheers Reid
Offline sjsargent
  • probationary
« Reply #3 on: July 16, 2014, 06:33:37 AM »
Thanks alot Reid,
« Reply #4 on: March 18, 2015, 05:07:42 PM »
on the same subject...is the flywheel clutch and preasure plate the same...
« Reply #5 on: March 18, 2015, 06:15:43 PM »
3 & 4spd ausies share the same flywheel/clutch& pressure plate it depends on which 5 spd you are using as to what clutch/pressure plate you need and the auto uses a flex plate  ;D ;D ;)   Cheers merlin
« Reply #6 on: March 20, 2015, 03:51:06 PM »
thanks..its ozzy 4 speed...
« Reply #7 on: March 20, 2015, 05:58:03 PM »
Yeah ive only heard of M20 and M21.
When converting from auto to manual dont forget to put the spigot bush in the end of the crankshaft.
The 4 speed ausie gearbox needs this.
The auto has a large round center on the torque convertor that slips into the crankshaft, where the manual gearbox has a thinner spigot shaft.
http://m.ebay.com.au/itm/251879643389?nav=SEARCH
« Last Edit: March 20, 2015, 06:01:37 PM by Marishka »
