  • Dot Guests: 253
Author Topic: new fuel gauge /sender  (Read 7978 times)
Offline vanpyre
    • Fairlanes and custom vans
« on: June 28, 2014, 01:08:24 AM »
Hi guys im after  a bit of technical advice i want to run a 52 mm fuel gauge in the bedford does anyone now of a kit  that comes complete with sender or a unit that will wire up to my existing sender unit   something hopefully that wont cost the earth to buy
cheers Vanpyre
Re: new fuel gauge /sender
« Reply #1 on: June 28, 2014, 06:43:35 AM »
I used a VDO 52mm gauge in my previous van and the supplier was able to provide me with a matching sender unit and sealing ring. From memory I just had to trim the existing sender hole to suit the new sealing ring. The sender came with a very long arm and instructions on how to measure and cut it to suit the depth of the tank. I sourced it from a specialist car parts company. Try these fellas : http://www.aisat.com.au/
Offline vanpyre
« Reply #2 on: June 28, 2014, 09:52:15 AM »
thanks mate ill take a look
« Reply #3 on: June 28, 2014, 01:22:40 PM »
Or you could try some of the digital gauges, they can actually be calibrated fairly easy, using the buttons on the gauge.
