  • Dot Guests: 156
Author Topic: Turbo 202  (Read 26271 times)
Re: Turbo 202
« Reply #20 on: July 18, 2014, 12:39:42 PM »
interesting about the gasket, I've been racing with a turbo 202 for a few years now and I have never had an issue with the intake/exhaust gaskets failing! .... but mine is a blue motor so maybe they are different, I use the metal faced gasket on the inlet/exhaust and its worked fine! wish I could say the same for head gaskets!
but I definitely have to agree of the performance gains from a turbo :)
Offline Mr Whippy
Re: Turbo 202
« Reply #21 on: July 18, 2014, 10:49:31 PM »
I've put it down to having higher exhaust temps due to LPG . On my beddy after 1000 kays the composite manifold  gaskets end up turning into carbon around the exhaust ports. The head gets so hot that it has burnt the paint above the exhaust ports right off!
Have never had an issue with head gaskets though, 10 psi is fairly modest boost.
Re: Turbo 202
« Reply #22 on: August 17, 2014, 05:01:21 PM »
Ok the extended sump was painted and ready to go in as well as the extended oil pick up.
Ray went to fit the sump and it hit the cross member @$!&%$! was what came out of the shed when i dared to venture up there to see how he was going...why oh why didnt i just keep it standard was his grumbling and complaining...everything is a bloody stuff around and never straight forward on a beddy.  :(
...so the steering had to be dropped  to give access and a thin slither had to be taken away from the crossmember to get the sump in. And also had to jack the motor right up to the floor to give room to get the sump in too.
And to answer all your questions ...it took  9 litres of oil to fill up the  extended sump  :D
we also fitted a standard JP oil pump and took her for a test run.....wow no oil leaks!
looking forward to doing the wollongong van run next weekend!
Offline Bedford Fever
Re: Turbo 202
« Reply #23 on: August 17, 2014, 06:03:57 PM »
     That is one beautiful sump , wouldnt look out of place in an art gallery.
     Your husband has some tremendous skills .
     Keep up the fantastic work.
     Cheers frank
Offline Rotti
Re: Turbo 202
« Reply #24 on: August 17, 2014, 10:50:47 PM »
geez that sump is too pretty! :D
looking great guys!
Re: Turbo 202
« Reply #25 on: August 19, 2014, 01:35:43 PM »
yeah nice work! but I don't understand why you had to lower the steering ? or was that just to get it in ? I thought the only part of that modified was the rear ?
Re: Turbo 202
« Reply #26 on: August 19, 2014, 03:29:27 PM »
yeah Sammy it was  just to get it in  ;)
Thanx Frank & Rotti ...yep Ray is pretty handy with a welder!  :D
the curved bit came from a fellow who marinanises engines for boats and he makes new sumps with that style to suit the bottom of the hulls.
I do hope the rest of the fit goes more smoothly.  ;D
Offline phullbore
Re: Turbo 202
« Reply #27 on: August 19, 2014, 06:15:19 PM »
Do you reckon that winged keel will improve your aero???? ;)
Re: Turbo 202
« Reply #28 on: September 06, 2014, 06:28:42 PM »
Its turbo time !!!!! [/size]  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Ray put the turbo, manifolds and all the pipes on the 202 today!!
wooo hoooo!
The first vdeo is the inital start up, with no muffler attached yet!
http://youtu.be/7Z16UQ_maZU
The second video is seeing what boost she is putting out....its noisy as we havent hooked up the muffler and the white smoke it the paint on the new exhaust manifold...the turbo boosting at 6 PSI.
http://youtu.be/1wp184xomS4
Re: Turbo 202
« Reply #29 on: September 06, 2014, 07:33:54 PM »
Hey Ray I thought my motor was flash but polished inlet manifold holy crap im gona have to pull mine apart again haha Looking good
