  • Dot Guests: 344
Author Topic: locking fuel cap  (Read 20052 times)
Offline GARRY
locking fuel cap
« on: May 18, 2014, 11:01:54 AM »
Have been searching through the site but can"t find any info and have searched the TRIDON site with no luck. I need a locking fuel cap it"s 100mm across & the centre is about 50mm anyone know of one or something from another vehicle that might fit.  ???
Offline maicoletta
  • Beddy til I die!!
Re: locking fuel cap
« Reply #1 on: May 18, 2014, 08:48:05 PM »
I'd love to know too!
I bought one ages ago from ebay.co.uk, but wasn't even close to fitting- not sure if I've got an original size cap/neck combo as Bessie is well camper&custimised already.
I'll take some measurements of the one I bought next time I'm at the shop, and if it fits, its yours if you want it!
Al
« Reply #2 on: May 20, 2014, 02:40:14 AM »
we do need to sort this one, I think there was two sizes originally, small / large.....I too need a new Large one LWB.....nose to the ground peoples...
Offline Truck
« Reply #3 on: May 20, 2014, 08:23:22 PM »
« Reply #4 on: May 20, 2014, 08:53:27 PM »
Good find Truck.
Is there a section in the forum categories that these "contacts" can be stored?.... like the door locks
« Reply #5 on: May 20, 2014, 09:22:13 PM »
 Cheers Truck,  a quick site search found these ...I will give them a call tomorrow, and poss order the larger one if all well....shouldn't be a prob as those (pic #) are the part # for the Beddie....
http://www.cpcauto.com.au/catalogue.aspx
« Last Edit: May 20, 2014, 09:25:34 PM by Dano »
Offline Truck
« Reply #6 on: May 20, 2014, 09:28:12 PM »
I think I found a CPC unit for van a few years back but when I got new van decided I wanted to eliminate the big cap look so had the cover in below link grafted into panel and looks a treat.
http://www.tanksinc.com/index.cfm/page/ptype=product/product_id=103/category_id=60/mode=prod/prd103.htm
Offline GARRY
« Reply #7 on: May 21, 2014, 07:49:27 AM »
Thanks fellas i"ll go to repco and order one today. ;D
« Reply #8 on: May 25, 2014, 01:46:44 AM »
ah Truck ,you've been a busy boy....love the link thanks bud, I have a custom filler set up for the SWB but  how did you go with the breather set up?
Let us know how you go Gaz, I never got a chance to ring these guys, I'll try again on Monday...
« Last Edit: May 25, 2014, 01:51:37 AM by Dano »
Offline Truck
« Reply #9 on: May 25, 2014, 01:59:30 PM »
Yeh Dano been a little busy when I could get time away from work. I tried for months to get the whole fuel door and filler of a wreck from both wreckers and gumtree but no one would let me cut it out of panel so had to look at other options and found the one in above link. Cost was $140 delivered with a spare push thru cap and I fitted the breather pipe to the supplied filler pipe. The door is a little small which is why you need the push thru cap as it would be a bitch trying to remove the cap at each refill and cap also secures filler pipe to the body. Overall very happy with it and it blends in very well.
Cheers Greg
