  • Dot Guests: 190
Author Topic: Adjustable upper arms  (Read 24330 times)
Re: Adjustable upper arms
« Reply #10 on: May 14, 2014, 01:21:47 PM »
WOW THATS OVERKILL......
« Reply #11 on: May 14, 2014, 02:57:40 PM »
Sorry fellas, my bad, should read 1 inch diameter with quarter inch wall thickness :-[
« Reply #12 on: May 14, 2014, 08:13:55 PM »
seems like a waste of time & effort to me ,all that work to fabricate adjustable arms and in the end all you've got is a comercial front end designed for load carrying not handling,if you go with the Jag front for instance they come with full tuneability including anti dive/squat built in and you can even tune in the ackerman point for different wheel bases ,ya cant beat them they come with Kiiller brakes and they're holden stud pattern and they're fairly cheap well thats my 2 cents worth   cheers Merlin
Offline Truck
« Reply #13 on: May 14, 2014, 11:33:33 PM »
Merlin where can you get this Jag set-up you speak of and what would cost be?
Or do you still have one under bench?
« Reply #14 on: May 15, 2014, 01:03:57 AM »
ive still got the modified bedford f/end that uses jag suspension and commodore power steering but i can set up a Jag f/end easily enough you're welcome to come and look at my chassis setup if you want truck    Cheers merlin
« Reply #15 on: May 15, 2014, 05:52:44 AM »
I hear you Merlin and in hindsight that would have been the way to go, but having already bought the dropped stubs and the bottom arms modified and crack tested I'm too far in to turn back now.
Offline Rotti
« Reply #16 on: May 15, 2014, 08:41:32 AM »
I was thinking of lowering my old girl, but seems a bit of a drama, will eventually throw these under the rear to fill the guards up, the fronts look similar, just thinner & more tread! with a gps speedo, that should sort it easy :)
Firestone's Drag Slick whitewall tires. Made in the USA. DOT approved. Street and stripe compound. Built in new molds from original Firestone drawings.
« Reply #17 on: May 15, 2014, 03:41:00 PM »
sent messages but your not getting back to me????
« Reply #18 on: May 15, 2014, 05:40:16 PM »
huh?? ive had no messages about this .wot yoo talkin bout willis???!!! :P
Offline Truck
« Reply #19 on: May 15, 2014, 10:21:23 PM »
Merlin definately keen to check this option out and discuss how best to proceed. When you get five can you msg me your contact details?
Truck
