  • Dot Guests: 298
Author Topic: Overheating Red Motor  (Read 9602 times)
Re: Overheating Red Motor
« Reply #20 on: March 25, 2014, 12:58:16 AM »
Gordon, it sounds like the setup was capable in the past. The only other thing i recommend is running redline water wetter instead of 'coolant'. I run a bottle of water wetter with distilled water with no 'coolant' at all, tho the water wetter will work with a coolant mix, however at a reduced efficiency.
The electric fan is fairly easy to swap for your mechanical fan, and would be good for a comparison if nothing else
Although the 160F thermostat is probably the cheapest and easiest modification
« Reply #21 on: March 25, 2014, 05:21:29 AM »
MaTTe, thanks for the additional advice and pointers. I'll let you know how I get on. Cheers Gordon
