  • Dot Guests: 298
Author Topic: NEED HELP PLEASE  (Read 10896 times)
Offline Truck
Re: NEED HELP PLEASE
« Reply #10 on: March 19, 2014, 11:08:37 PM »
Hi Maureen,
Agree with Rumax and before selling check with transport dept. as they will clear up the question of towing capacity and also be able to give some information on draw bar requirements. Overall the power of engine will keep you cruising but might take a little longer to get there and will most likely make some hills feel like mountains.
Offline Maws1948
« Reply #11 on: March 20, 2014, 09:14:13 AM »
Thanks for your advice, much appreciated... :o ;D
« Reply #12 on: March 21, 2014, 12:06:51 PM »
Hi Maureen, George again, try these unlikely suspects, if they can't help with your motor  then know one can. Good luck. Feel free to email me if you need any other advice, that's what makes BUGA number 1.
Warren,
Mezmo,
Busykiwi
shane
Regards george
« Reply #13 on: March 21, 2014, 03:30:14 PM »
Hi Mureen
If you are using an a frame I would think the van should tow it, the holden 6 and trimatic is a pretty good combo, do you know what ratio your diff is, that has an effect on preformance and cruising speed, and when bedfords came out they had a ration of 4:00 to 1 and they would only get up to bout 80kph. Thats why you see talk of "Highway Diffs"  they tend to have ratios between 3.5 to 2.87 for improved top speed cruising.
With its weight near 3 tonnes thats preety heavy, Id be looking to put the van on a diet or possibly go for a later model 5 speed auto (with overdrive) to better use the power of the engine.
« Reply #14 on: March 22, 2014, 05:26:05 PM »
Hey guys, Maureen has just brought to my attention that i am now an apprentice mechanic,  ;D ??? ::) :o ;D ;D in my dreams, i am no more a mechanic then Maureen. I did not put that on my avatar, can someone take it off for me, or show me how. Thanks guys.
« Reply #15 on: March 22, 2014, 06:20:28 PM »
Hey George It's a badge of honour Wear it with pride
« Reply #16 on: March 22, 2014, 06:22:13 PM »
Yeah its better than full of bog, , ;D
« Reply #17 on: March 22, 2014, 10:24:35 PM »
HAHAHAH good luck getting rid of that!  :D
I noticed that when mine said full of bog. ??? was not impressed...i was assured it was just levels we all go thru as we post things here on buga...something they come up with when developing this forum  ;D it shows years of bedford owners ship  ::) ....wisdom or madness u be the judge LOL  :o  ;D  ;)
Offline Maws1948
« Reply #18 on: March 23, 2014, 08:23:44 AM »
APPARENTLY I'M A GUMBIE[
Gumbys are recurring characters in Monty Python's Flying Circus, characterized by a very distinctive appearance. Gumbys are portrayed with toothbrush moustaches, wear handkerchiefs on their heads[1] which are knotted at the corners, wire-rimmed spectacles, braces, Fair Isle knitted tank tops, a 1950s shirt rolled up to the elbows (without the detachable collar), trousers rolled up above their knees and gumboots. The characters usually hold their arms in an ape-like position, speak loudly and slowly, and pronounce words syllable by syllable. Though created by John Cleese, the Gumbys were most often played by Michael Palin. Graham Chapman, Terry Jones and Cleese also had noticeable solo turns as Gumbys. Palin's Gumby voice was used to announce the show title in series three
« Reply #19 on: March 23, 2014, 09:12:46 AM »
Ok, well i always knew i would wake up one morning and i would be a tradie, cant wait to wake up tomorrow and my legs have grown back and i am cruising in my beddie.  ;D ;D ;D ;D ;D
ok now that i am a mechanic, here is how you change your engine oil, you grab a thingy majig, and undo the thingy maig, then drain the thingy majig, b4 screwing your thingy majig. So guys if you want to screw your beddy up just send your questions my way.  ;) ;) ;D ;D ;D you gotta love it. ;D ;D ;D
