  • Dot Guests: 318
Author Topic: Pinion seal which direction does the lip and gaitor ring go  (Read 5400 times)
Offline green beast
« on: March 08, 2014, 09:44:13 AM »
Hi there folks,
I replaced my pinion seal a few months back, recently noticed a leak, took it to a mechanic friend who said I had the the seal in backwards, he put it in the other way round, a week later pretty much all of underneath the van is covered in gear oil. I had a look and half the seal is destroyed, oil coming from seal, before it was coming from the housing. So, this time, I have a new seal and a new bearing and will be using some sealant to doubly make sure. But! which way round does the seal go? Pictures follow, various website forums say different things, I asked a few mechanics, majority answer is lip and gaitor - (metal band) go towards the diff - which is different to what mechanic friend reckons. Anybody know for certain??
Thankyou for any help
Re: Pinion seal which direction does the lip and gaitor ring go
« Reply #1 on: March 08, 2014, 10:25:30 AM »
Second photo, shows the correct way
Offline green beast
« Reply #2 on: March 08, 2014, 11:33:15 AM »
Thankyou for the quick reply!
« Reply #3 on: March 08, 2014, 01:13:31 PM »
The metal band goes inward, so all you will see once in place is the rubber part... when looking at the end of the diff..
« Last Edit: March 08, 2014, 01:16:58 PM by Bas / NZ »
Offline Postie Bob
« Reply #4 on: March 09, 2014, 01:39:13 PM »
Make sure there`s not a groove worn on the pinion shaft where the seal lip runs .
Can/would that happen?
Cheers, Bob.
