  • Dot Guests: 318
Author Topic: 1971 Bedford CFS 350 Chev T400 on Gas  (Read 38914 times)
Re: 1971 Bedford CFS 350 Chev T400 on Gas
« Reply #30 on: May 21, 2014, 04:35:57 PM »
yeah i  agree 16-17 max for older stuff!
Offline Ash
    • Zahl 1 Karting
« Reply #31 on: June 07, 2014, 04:25:50 PM »
There is a lot of love out there for a Bedford van. Getting a couple of enquiries each day. I have hundreds of swap offers which all get turned down. I have taken some more photos that people have asked for.
Photo of the rear. The bottom corners under each side there is some filler. Doors are an easy repair but no need to with the 2 spare in the rear that are perfect.
Bedford enthusiast
Offline Ash
    • Zahl 1 Karting
« Reply #32 on: June 07, 2014, 04:28:32 PM »
Left front guard including the dogleg behind the wheel all metal. Start of the front door just below the mirror there is a small bit of filler about a 20 cent piece.
Bedford enthusiast
Offline Ash
    • Zahl 1 Karting
« Reply #33 on: June 07, 2014, 04:30:18 PM »
Front door all good except for what I mentioned above. Original door handle, door lock, window winder etc all work perfectly.
Bedford enthusiast
Offline Ash
    • Zahl 1 Karting
« Reply #34 on: June 07, 2014, 04:32:03 PM »
Perfect except for the scratch and small paint repair. Note the gas filler on this side.
Bedford enthusiast
Offline Ash
    • Zahl 1 Karting
« Reply #35 on: June 07, 2014, 04:34:16 PM »
Still good except for the filler in the lower back corner, but its at the very back only under the bumper.
Bedford enthusiast
Offline Ash
    • Zahl 1 Karting
« Reply #36 on: June 07, 2014, 04:36:35 PM »
Bonnet all good. Catches etc all work. Paint repair on lower edge of bonnet.
Bedford enthusiast
Offline Ash
    • Zahl 1 Karting
« Reply #37 on: June 07, 2014, 04:38:13 PM »
Rear left, you can see the filler under the hinge. Door easily repaired if you wanted to. Hinges all good.
Bedford enthusiast
Offline Ash
    • Zahl 1 Karting
« Reply #38 on: June 07, 2014, 04:40:50 PM »
Rear right, you can see the filler under the hinge. Door easily repaired if you wanted to. Hinges all good. Handle works fine. Repair under the paint lifting just below the handle. Has 2 perfect rear dorrs as spares that go with the van so no need to repair them.
Bedford enthusiast
Offline Ash
    • Zahl 1 Karting
« Reply #39 on: June 07, 2014, 04:42:16 PM »
Right rear, very good condition. Note the original filler not in use.
Bedford enthusiast
