  • Dot Guests: 302
Author Topic: brand new door locks barrels  (Read 23041 times)
Re: brand new door locks barrels
« Reply #10 on: December 30, 2013, 06:47:29 PM »
Thanks, ill give that a try ;)
« Reply #11 on: January 16, 2014, 07:11:58 AM »
Turns out they are an easy change over.
A circlip holds the door lock n handle together ,
Then you will need a key to get the lock out,
(Just locate as many old keys as you can, borrow a few if nessasary)
To find 1 that fits.
Press the little button while removing the barrel
And presto.
Finee,:)
 P.s.  If you dont have a key entry on passanger side
You can just get a spare drivers side key push button and
Install it into the passange handle.
Easy as, im just in the process of doing this and installing central locking,
And putting electric windows in all 3 of my bedfords
« Last Edit: January 16, 2014, 09:12:06 PM by mty »
« Reply #12 on: January 16, 2014, 09:48:12 AM »
handy pictures and info thanks! I've ordered a set of the ebay landrover locks so will be doing the same shortly!
« Reply #13 on: January 16, 2014, 02:09:03 PM »
Yeah i bought 2 sets,
I might buy 2 more sets n put them away,:)
« Reply #14 on: January 16, 2014, 09:17:52 PM »
Good thing about these locks is there are 4 locks per pack
So if you have 3 bedfords with only a drivers door and back door lock
You can have 1 key to fit both beddy,s lol,
« Reply #15 on: January 17, 2014, 12:27:48 AM »
Thanx heaps vuuup
Awsome reaserch there, you did well
, i ended up buying another 2 sets
And put them away for a rainy day,:)
Cheers marty
« Reply #16 on: January 17, 2014, 07:03:16 AM »
The guy is wondering why there has been such a demand for the locks, price might go up when he finds out... ;)
I got a set, quick delivery to NZ, but as I have only 3 doors, I have a spare, so 1 set will do, as I am sure they will out last me...... :D
« Reply #17 on: January 18, 2014, 01:31:16 AM »
AWESWOME!!!! thanks Vuuup....your a champinion....lol......top work !
« Reply #18 on: January 23, 2014, 08:33:01 PM »
Did rear door lock in 20 mins,
I advise using circlip pliers to remove circlips
Not scribers,  ( stabbed myself in the hand with scriber)
1/ remove circlip
2/ remove spring n washers
3/ remove little pin in main handle body
4/  put door opening cam on new lock.
5/ put back together and finneeto
Both front doors and rear door locks changed, 20 mins each,
Now to take ignition to locksmith n get it matched to door key.
Thats blueonblack (blue van done) will do nightingale (green n white poptop)
In next few days, :)
« Last Edit: January 23, 2014, 08:53:35 PM by mty »
« Reply #19 on: January 23, 2014, 09:09:05 PM »
Good info!! Mine turned up in the mail today ;) hopefully get time to fit mine soon!!
I love that each barrel comes with a set of keys ... Shouldn't run out !!!!
