  • Dot Guests: 257
Author Topic: beddy diff  (Read 3299 times)
beddy diff
« on: December 09, 2013, 12:06:50 PM »
hi groovers.. have found diff oil pissin out the d/s of the diff ..... do we have any exploded diagrams of  a beddy diff on here??.. had a look but nothin came up...just wanted to know  if the only seal in the diff is the rubber ring that is around the wheel bearing outer???...  as it seems a bit pissweak, for a seal.. any info on stemming this would be well appreciated .. cheers guys...  ;)
Re: beddy diff
« Reply #1 on: December 09, 2013, 12:44:26 PM »
found the manual... has exploded diff diagram but no index  .. am i right in thinking a seal should be in the housing that the axle  slides through before the bearing goes in the housing??? thanks for input
Offline BeerBeddy
Re: beddy diff
« Reply #2 on: December 10, 2013, 01:37:17 PM »
That sounds about right for most vehicles I've worked on and I can't imagine the Beddy engineers invented something better.
Some bearing set ups have a seal in the actual bearing, then the main seal between the bearing and the axle flange.
Others will know for sure as I'll wager yours are not the first axle seals to leak.
Beerbeddy
Re: beddy diff
« Reply #3 on: December 10, 2013, 02:10:33 PM »
I have just put my diff back together, and to the best of my Knowledge, the only seal was the O ring on the bearing?
