  • Dot Guests: 257
Author Topic: Gearbox swap Q  (Read 6317 times)
Offline Postie Bob
Re: Gearbox swap Q
« Reply #10 on: December 20, 2013, 09:51:01 AM »
Have identified the` mystery bits `.
I recon the tooth is/was part of a reverse gear . The small flat bit of metal was the spring from the anti lash plate under the reverse gear .
The piece with the hole is the end of the circlip holding the rear bearing in place. ( both ends of the circlip are gone  >:( ) .
There must have been some major destruction happening in there. The broken circlip is still doing it`s job though .
They say " nothing is impossible " , getting that circlip out now would be very close to the `impossible` .
Whoever repaired the box must have done it on the side of the road  ;D .
Anyway , all seems ok now so will swap it over when I get some other projects out of the way.
Cheers `n` Merry Xmas to all.
