  • Dot Guests: 207
Author Topic: Gearbox swap Q  (Read 6305 times)
Offline Postie Bob
Gearbox swap Q
« on: December 01, 2013, 05:12:34 PM »
I picked up a 4 speed gearbox to replace my old 3 speed but it seems I could be in strife with the linkages setup.
The selector bit is at the back of the 4 speed whereas it`s at the front on my 3.
Is there a writeup or something on this changeover? Am I going to have to cut a hole back further for the shifter?
Cheers , Bob.
Offline ethyl
Re: Gearbox swap Q
« Reply #1 on: December 01, 2013, 07:39:56 PM »
I have a modded 4 spd shifter to fit at the front and changed operation for reverse, It's in the shed some where at the farm.
I took the 4 spd out to fit toyota 5 spd. be up there Tuesday night if I remember could get a pic.
Offline Postie Bob
Re: Gearbox swap Q
« Reply #2 on: December 01, 2013, 08:01:00 PM »
Thanks for the reply ethyl .
I would be interested in the shifter for sure.
I most probably wont be doing the changeover till after summer ( when it runs out of rego ).  Hopefully keep the `ol dear runnin till then  :) .
At the moment Im working on getting her ready for a paint job.
Re: Gearbox swap Q
« Reply #3 on: December 02, 2013, 08:58:23 AM »
Cheers , Bob.
Bob
I posted a reply to a question you asked previously about this (see some of your previous posts) and also I have commented on this very thing before.
"When I bought the 4 speed it came out of a holden one tonner, and I got the box and shifter.
when I installed the gearbox I mounted the shifter in the standard position (bolts straight in) I also used the two three speed linkages for the forward gears (no mods required) and one of the 4 speed linkages for reverse Had to mod it a bit, (cut and bend from memory).
I also had to rebend the reverse selector leaver up a bit to stop it fouling on the bell housing, nothing drastic, and bend the stub that the gear lever sit on forward so that the gear sits forward.
Have a look at my gallery for some pics."
When you get closer to doing it and need more info PM me your number and I can talk you through it.
Offline Postie Bob
Re: Gearbox swap Q
« Reply #4 on: December 02, 2013, 09:33:08 AM »
Thanks for the assist Warren .
Maybe not so much of a drama after all  :) .
Offline Postie Bob
Re: Gearbox swap Q
« Reply #5 on: December 02, 2013, 04:52:03 PM »
I fitted the 4sp shifter to my 3sp box today so thats a start eh .
Ethyl , I will have to pass on the shifter you mentioned . Thanks anyway ( hope I haven`t put you to too much trouble ).
I will wait for a rainy day and pull the 4sp apart to make sure it`s ok before I bung it in .
Offline Postie Bob
Re: Gearbox swap Q
« Reply #6 on: December 05, 2013, 07:17:34 PM »
Took the side off my 4 speed (M20) and found these UFO`s  inside   ??? .
The gears all look fine so am wondering where they came from .
Can anyone recognise them?
Surely someone wouldn`t repair a box and leave these inside!!
I didn`t want to disassemble it but maybe no option  :'( .
 [img][C:\Users\pirie\Pictures\gearbox ufo`s\DSCF1305.JPG/img]
Offline Postie Bob
Re: Gearbox swap Q
« Reply #7 on: December 05, 2013, 07:23:49 PM »
Still havin trouble with putting up pics  >:( .
Have put one in my gallery...
Re: Gearbox swap Q
« Reply #8 on: December 05, 2013, 07:59:16 PM »
try this.... maybe
Re: Gearbox swap Q
« Reply #9 on: December 05, 2013, 08:00:20 PM »
Postie Bob, I think the file was too big.  ;D
