  • Dot Guests: 340
Author Topic: Softer front springs  (Read 4900 times)
Offline vangard
« on: November 18, 2013, 06:55:40 PM »
Anyone know if there are any softer front springs that could be used in the CF?  I find the ride to be a bit bouncy bouncy.
Re: Softer front springs
« Reply #1 on: November 18, 2013, 07:27:25 PM »
If it's bouncing the shocks are stuffed softer springs will only make it worse
« Reply #2 on: November 19, 2013, 04:56:35 AM »
Add some weight to the van, they always handle better with weight, empty they just bounce around
Offline vangard
« Reply #3 on: November 20, 2013, 01:17:14 PM »
Thanks for the replies fellas.  Didn't really want to add more weight as it's a Dormobile and weighs 1800kg already.  And when we travel my wife likes to collect rocks when I'm not looking.  I'll check the shocks when I get some time off from restoring the Armstrong Siddeley.
« Reply #4 on: November 21, 2013, 11:06:44 AM »
hi am gonna be putting in heavier springs from a LWB front end sometime soon, into "ol futile".. if you want me too let you know if it improved on the bounce syndrome??
Offline vangard
« Reply #5 on: November 21, 2013, 04:55:23 PM »
Yes I'd be interested in how the heavier springs perform, thanks.
« Reply #6 on: November 21, 2013, 09:13:38 PM »
test your shocks by bouncing up and down at one corner of the vehicle 2 or 3 times and let it go ,if it bounces more than 3 times IE: up once,down once,and then up again then your shocks are suspect ,The general rule is :springs transfer road shock into linear movement and shocks absorb that road shock so if the vehicle is "bouncy" then the shocks are either under rated for the weight of the vehicle or theyre just simply shot ! anyway hope that helps   Cheers Merlin
