  • Dot Guests: 235
Author Topic: lowering  (Read 9128 times)
Re: lowering
« Reply #10 on: November 15, 2013, 07:43:55 PM »
Hey Mezzmo,
Where can we buy drop spindles and are they legal?
In NSW?
Cheers marty
Re: lowering
« Reply #11 on: November 16, 2013, 05:03:45 AM »
Hi Marty,
apparantly they come with an engineers report so don't see wht they wouldnt be legal.
See link:   http://www.stubtech.com.au
Mezz
Offline Mattty
Re: lowering
« Reply #12 on: November 16, 2013, 09:35:35 AM »
Hi
Has any body on here bought them? if so how much?
Thanks Matt
Re: lowering
« Reply #13 on: November 16, 2013, 09:45:24 AM »
expensive around $900
Re: lowering
« Reply #14 on: November 16, 2013, 10:09:10 AM »
Cheers Mezz,
$900 isnt too bad, id pay that to lower a beddy,
I might buy another LWB to hot n tart up.
Re: lowering
« Reply #15 on: November 16, 2013, 11:23:07 AM »
Folk, think very carefully before you dive into going down the dropped stub axle path. There are lots of additional costs that you will incur on top of the cost of the dropped spindles. The lower arms need to have the existing ball joint seats cut out and the new seats supplied with the kit re-positioned and welded in. You then need HQ lower ball joints and HQ wheel bearings. You also need machined spacers to fit standard Bedford steering arms to the Stubtech axles. I'm now battling with my disk setup as a standard HQ disk no longer clears the modified lower suspension arm so I am looking at going to a separate top hat style wheel hub with a separate disk that can be spaced to clear. My cert engineer specified TIG welding on all components which I had to get done by an engineering shop. I also needed to get all of the welding crack tested and a formal report for certification purposes. All up I've probably spent $2,000 and I still have the top hats and disks to buy.
Re: lowering
« Reply #16 on: November 16, 2013, 12:01:33 PM »
I was quoted $1250.00
