  • Dot Guests: 70
Author Topic: Drivers side window  (Read 5408 times)
Offline Floatncoffee
Drivers side window
« on: September 17, 2013, 01:06:56 PM »
Drivers side window wanted for 77 LWB...
SE Vic preferably
Offline BeerBeddy
Re: Drivers side window
« Reply #1 on: September 19, 2013, 03:22:07 PM »
If they are the same as SWB I have one in Geelong.
Beerbeddy
Offline vuuup
« Reply #2 on: September 19, 2013, 07:22:52 PM »
i believe they are the same as i have one in my lwb
« Reply #3 on: September 19, 2013, 07:30:08 PM »
swb and lwb are the same
left and right are the same, just the bottom channel is opposite
« Reply #4 on: September 26, 2013, 06:30:28 AM »
can you swap them over busy?
« Reply #5 on: September 26, 2013, 07:49:27 AM »
Sure can, use a rubber mallet and carefully bang it straight down and install by tapping on with rubber mallet. Don't place top of window on ground (concrete, steel) or any solid surface, across a bench is best.
Also be sure to measure and mark them, because if they are over one way to far the wheel will keep popping out.
It has a rubber material behind the steel plate, this is what keeps it on, ideally use the rubber again but if you can't then you can use a urethane but glass and channel has to be super clean
« Reply #6 on: October 06, 2013, 06:12:08 AM »
Does that mean the glass is flat?
« Reply #7 on: October 06, 2013, 06:17:16 AM »
Yes
Offline BeerBeddy
« Reply #8 on: October 06, 2013, 04:00:26 PM »
Like the earth?
« Reply #9 on: October 06, 2013, 05:55:02 PM »
what on earth are you talking about... ;)
