  • Dot Guests: 325
Author Topic: 4cyl auto convertion  (Read 6459 times)
Offline aussie
  • It's Buga owning a bedford
« on: September 11, 2013, 07:38:48 PM »
 :)Hi All,
I have a 74 cf doormobile from the u.k, It's got oridginal slant 4 vauxhall motor & gearbox, would like to upgrade to bigger 4cyl auto or even v6 auto if feasable, would welcome any help, maybe some of you vanners out there have something for sale,
i live in qld phone 0428 252 360
thanks
Aussie
aussie buga
Offline ethyl
Re: 4cyl auto convertion
« Reply #1 on: September 12, 2013, 07:27:09 PM »
why not a Holden 6 202 conversion? standard parts for that available.
Offline aussie
« Reply #2 on: September 13, 2013, 07:02:12 AM »
hi ethyl,
Being imported uk model not sure if eng & g/box mounts are in same place ? are conversion kits available ? if so do you know where I can purchase from. Thanks Aussie buga
aussie buga
« Reply #3 on: September 13, 2013, 07:58:17 AM »
Having gone down the V6 conversion route, i wouldnt do it again! having to do the discs etc was real pain too and i still reckon their no different to drums re stopping power. For my two cents worth, i'd put feelers out for a stock 6 cylinder front end or buy a basket case Beddie for a couple of hundred bux and get even more parts. that way you have the original engine mounting blocks and its just a matter of bolting up.
« Reply #4 on: September 13, 2013, 08:12:48 AM »
Mezz is right Get a rusted out dunga & rat all the mechanicals out of it & you will have plenty of spares You might even make a few bucks out of parts you dont need
Offline kimbosound
« Reply #5 on: September 13, 2013, 11:27:07 AM »
Here is a cheapie with all the running gear you would need....and its a camper....may have some other bits and bobs
http://www.ebay.com.au/itm/Bedford-CF-Camper-1975-with-3-SP-Manual-Trans-/321201482905?pt=AU_Car_Parts_Accessories&hash=item4ac919ac99
Offline aussie
« Reply #6 on: September 13, 2013, 10:37:34 PM »
Hi Guys & Gals,
thanks for the info, will take it on board and keep you posted on my progress with the old girl
Aussie
aussie buga
Offline willo
« Reply #7 on: September 15, 2013, 08:04:24 PM »
:)Hi All,
thanks
Aussie
Hi mate,
having just done the v6 commodore and 4 speed auto my first suggestion is ... talk to your local RTA mechanical engineer who will need to sign it of for registration.  There are all sorts of rules about how much of an increase in CC's and/or power (either one can cause you grief in NSW) and how many of the donor vehicle ADR parts have to be fitted.  eg collapsible steering column, retractible seat belts, etc.  One good thing for me is the brakes didm't have to be done because braking efficiency is rated on the original weight and not the new motor.
Neil
Offline aussie
« Reply #8 on: September 15, 2013, 08:40:15 PM »
Hi Willo,
thanks for the advice, I have just made contact with a bedford guru @ bedfordmanor in brisbane   sounds like he knows a lot about these old girls and has all the parts required for a 202 auto change over even got HQ discs and diff if needed, as these are std australian bedford parts I hope not any probs with qld trans when i go for reg. will post progress as it happens
« Last Edit: September 15, 2013, 08:42:24 PM by aussie »
aussie buga
Offline Brownie
« Reply #9 on: September 16, 2013, 11:24:07 PM »
G'day just reading about your dilemma ,I have had bedford's for over 30 years now & I actually have a set of steel factory mounting brackets from holdens that they used to sell to fit on the crossmember if you are interested ,still brand new never been fitted .I will sell for $50. Plus postage from Adelaide
Cheers Paul Brown 0409951996
