  • Dot Guests: 289
Author Topic: fuel sender ohms  (Read 7719 times)
Re: fuel sender ohms
« Reply #10 on: December 16, 2013, 10:17:09 AM »
Pete, your better to test it at the sender as you can loose a lot through the loom
Offline Sweet Shock
« Reply #11 on: December 19, 2013, 01:23:22 PM »
Thanx Busy Ill try that. The 2 thinks Im trying to work out are my speedo and fuel gauge. Im not sure what type of gauges I want to use so I got some cheap ones to fill in the holes and modified my Beddy speedo til I make up my mind. lol
Offline Sweet Shock
« Reply #12 on: February 08, 2014, 11:51:19 AM »
Ok Im starting to fiddle with my fuel gauge and sender again. At the sender in the tank I was getting 876 omhs and it kept going up to 921 ohms within 5 min. After 15 min its reading 161. After another 15 min it was 300 then 15 min later 152 Does anybody no why Im getting these type of readings and why is it going up and down slowly.  thanx Pete
Offline Sweet Shock
« Reply #13 on: February 08, 2014, 11:52:39 AM »
PS I just left the ohm meter connected and took readings
