  • Dot Guests: 135
Author Topic: Thermo Switch  (Read 4501 times)
Thermo Switch
« on: July 14, 2013, 07:30:46 AM »
Does anyone know if these are available in NZ or OZ. thanks
Re: Thermo Switch
« Reply #1 on: July 14, 2013, 09:02:55 AM »
You can get a kit from Davies Craig:
http://www.daviescraig.com.au/Controller___Switches-ELECTRONIC_THERMAL_SWITCH__12V_ONLY___PART_No__0402-details.aspx
Or if you're after a fixed temp switch you could grab a thermal switch from an electronics store and attach it to a relay:
http://search.jaycar.com.au/search?w=thermal%20switch
Re: Thermo Switch
« Reply #2 on: July 14, 2013, 09:39:06 AM »
Ok Thanks, will check these out, I know of the Davis Craig, but the one I know off fits into the Radiator hose, and causes problems leaking from people I know that have used it.
« Last Edit: July 14, 2013, 10:04:09 AM by Bas / NZ »
Re: Thermo Switch
« Reply #3 on: July 14, 2013, 11:30:27 AM »
Yeah the one you're thinking of is the mechanical thermo switch. Agreed -> they are crap!
Re: Thermo Switch
« Reply #4 on: July 18, 2013, 02:41:31 AM »
yuo mean the one what fits down the inside of the return hose rad inlet, shane??? yep!! got one if anyone wants it???? (went back to mechanical fan) it has thermal adjustable setting from within the cab,  just pay postage she be "all yours"" (never actually leaked, but fans fractured cores after a time ) very cheap effendi..  ;)
Offline BeerBeddy
Re: Thermo Switch
« Reply #5 on: July 18, 2013, 05:24:37 PM »
I've used the capilliary type (in the hose) on street cars and race cars, never had any trouble. Got to use the little wedge they come with for best results but hi temp silastic will work OK too.
The best thing about them is the it is adjustable and you can get it running at the right temperature for best performance.
Re: Thermo Switch
« Reply #6 on: July 19, 2013, 06:58:56 AM »
Ok, thanks Shane, went with the 0402 model from Davies Craig, but not available in NZ that I could find, only the other model.
Re: Thermo Switch
« Reply #7 on: July 19, 2013, 03:08:22 PM »
Hey Bas, keen to find out how it works out for you. Looks like a good clean option. Cheers Gordon
Re: Thermo Switch
« Reply #8 on: July 19, 2013, 04:04:52 PM »
Gordon, will let you know how it goes, just need to wait for it to arrive..
