  • Dot Guests: 301
Author Topic: Bailey Channel  (Read 13544 times)
Bailey Channel
« on: June 27, 2013, 06:41:17 PM »
Hi guys I am in the middle getting a few rattles out of the front doors Have been to clark rubber & checked out all there bailey channel & could only find the right width but it isnt the same depth Has anyone else had this problem & where did you get yours I dont think it's possable to get the very top one as it is about 40mm deep & must be special
Re: Bailey Channel
« Reply #1 on: June 27, 2013, 06:54:16 PM »
the front door rubbers are actually made up out of 4 different sizes, the top, bottom and sides are all different to each other so no replacement will ever be 100%
oops, sorry your talking window channel, it will fit up top, the channel is the same but the original was longer to flare over the steel lip
« Last Edit: June 27, 2013, 06:56:20 PM by BusyKiwi »
Offline ethyl
Re: Bailey Channel
« Reply #2 on: June 27, 2013, 06:55:42 PM »
top piece not available but I bought the other sections from Rares in Adelaide, fitted really well but not quite same as original
Re: Bailey Channel
« Reply #3 on: June 27, 2013, 07:04:37 PM »
Yeah the one I can get is the right width but not as deep as the standard one I just thought the glass might jump out if I use it but if yours is ok Il give it a try
Re: Bailey Channel
« Reply #4 on: July 01, 2013, 01:27:10 AM »
crap.... just wrote a "letter" on this ......then posted......failed!  tomorrow restoreid.....
Re: Bailey Channel
« Reply #5 on: July 01, 2013, 08:24:48 AM »
Dont ya just hate it when that happens haha
Re: Bailey Channel
« Reply #6 on: July 08, 2013, 10:19:03 AM »
ahh forgot about this, ok sorry for the time warp.... ok did a heap of research for our baileys channel but to no avail, sooooo best to use our original rubbers and re line them with a thin felt, that can /should be able to be purchase from your local dealers, then glued to the original baileys channel, I have some ready to do at home was thinking of doing a exchange thing if people are interested?
Re: Bailey Channel
« Reply #7 on: July 08, 2013, 10:32:55 AM »
more on this later when i can post some photo's to explain...
Offline VanWolf
Re: Bailey Channel
« Reply #8 on: July 08, 2013, 01:19:17 PM »
Try Spectrum rubber.
Here is a link to their catalogue.
http://www.spectrumrubber.com.au/images/stories/Spectrum_Rubber_Catalogue.pdf
Start at page 22.
Mike
