  • Dot Guests: 279
Author Topic: CF Bedford Window and door seals needed  (Read 3732 times)
Offline Stew
« on: June 21, 2013, 12:52:26 PM »
Hi guys other than rare spares is there anywhere else that sells the rubbers for Bedfords? And does anyone have a close up photo of the door seals you use. I took mine off years ago and need to have a close look. Cheers!
Re: CF Bedford Window and door seals needed
« Reply #1 on: June 21, 2013, 03:24:41 PM »
Clarke rubber have plenty of different styles of rubber, as a thought, if you can find the exact style, try finding one that you can fit to the van itself instead of to the door - i've seen it done and its very successful.
Offline VanWolf
« Reply #2 on: June 21, 2013, 11:19:36 PM »
Spectrum Rubbers in Sydney.
Offline chum_007
« Reply #3 on: June 27, 2013, 05:51:34 PM »
Purple Pig do some pretty kool stuff as well
Here is there rubber catalogue http://www.purplepig.com.au/files/bzusdqdmms/PIG500_R4-Rubber-Products.pdf
Pretty sure there was a thread on here with the correct part numbers and required amounts for a fit out.
