  • Dot Guests: 349
Author Topic: Sealing old revit holes  (Read 3195 times)
Offline walzaher
« on: June 14, 2013, 08:26:31 PM »
Hi everyone,
I have been searching but havent been able to find any answers. Today i took out the old board on the back of the van so i can clean under it, sand it down and insert it again and lay carpet over it. It had pop rivets holding it. After the horrible job of removing them, I am wondering what I can do to stop the holes where the revit pins were from starting to rust?
Thanks very much
Waseem
Re: Sealing old revit holes
« Reply #1 on: June 17, 2013, 12:49:28 PM »
paint or otherwise seal any bare metal surfaces. If your concerned with water getting in through the holes then seal them up with a clking compound (after youve painted them).
« Reply #2 on: June 17, 2013, 11:54:28 PM »
several options, use metal screws to re install floor(you can dip them with wax), tin snip little plates and glue with a silaflex type bond adhesive , weld of coarse, re rivet with larger rivets, but all in all once the floor is refitted, simply coat the fitting you use, either paint and or under body sealer/ it also is a sound deadner. Dano.
Offline walzaher
« Reply #3 on: June 21, 2013, 06:02:02 PM »
thanks for the advice =) very helpful!
