  • Dot Guests: 1103
Author Topic: My Bedford Idea - Twincharged V8.  (Read 10080 times)
Offline nathro V2.0
  • i not a gumbie...
« on: December 05, 2008, 11:15:45 AM »
Hi Everyone,
I have been toying with the idea of twincharging for a few years now (initially for my VL) and now for the Bedford but i have finally decided that i am going to do it.
I have done a fair amount of research but it is always good to get people's opinions as sometimes they think of things that i havent/wouldnt.
So here is what i am thinking. I have a semi-reconditioned 253 which i have fitted with 4 into 1 extractors with 3" secondaries. Basically i will keep the extractors and mount twin symmetrical turbos (one on either side) using a custom adaptor. The turbos will be relatively small as there will be two of them and i estimate that i will only require 5psi from each.
The turbos will be mounted such that the ambient inlet is forward and the exhasut outlet is rear. The pressurised outlet pipes will run beside the headers and over the steering rack to a custom intercooler that is long but narrow (allowing it to fit with the radiator etc). The way that these are run should mean that they will never be lower than the sump so there is less chance of damage etc.
Each turbo will be wastegated on the exhaust inlet prior to the turbo inlet exhaust and referenced to the pressurised air side such that if the pressure goes above 5psi then the gates open and exhaust is re-routed to after the turbo (but back into the exhasut). This will stop them from producing more pressure above the 5psi point.
On top of the engine will be a 4/71 (or possibly underdriven 6/71) roots supercharger with the pulley made to procude 5psi. This doesnt need a wastegate/BOV etc as it is direct drive so it is always producing the correct amount of air required at any given engine RPM.
On top of the blower will be an appropriate carby with the correct internals for pressurised air.
On top of the carby/s will be a custom plenum that is relatively shallow in terms of hieght (as clearance will be an issue) but about the same width and length as the blower. Two pipes will run from the intercooler up beside/in front of the radiator (but away from the fan etc) and then diagonally across to the plenum so that they join at the front.
On the back of the plenum will be another wastegate which will be referenced to the plenum pressure and set to open at 6psi in order to prevent spikes (the 6 is allowing for some leakage as the spring starts to open towards the 5psi mark).
So the pressure in the plenum will be at a maximum of 5psi based on the turbo gates and a max of 6psi in the event of an unlikely spike. That 5psi in the plenum will then go through the carby and into the supercharger which will further compress (pressurise) the air.
Theoretically if it is 5psi on entry and the supercharger is producing 5psi then it will be 10psi in the manifold however i estimate that it will onlybe around 8psi due to inefficiencies etc.
You may be asking why bother with tubo AND supercharger but there is method behind my madness. In order to explain it i need to give some simplified background info.
A supercharger can use up to 40% of the energy produced by the engine to power itself but it provides more power than it uses resulting in a net gain. However at high RPM's superchargers tend to be a lot less efficient than at low to medium RPM's.
A turbo however uses a lot less energy to power it as it is running of the waste gasses which arent directly connected to the crank. It is NOT free energy as the backpressure caused by the turbulent airflow presses on the cylinders thus making it harder for them to move (you need to look into the complexities of fluid mechanics for further info on it). But as with the supercharger it results in a net gain. One of the main weaknesses with a turbo is that they need to spool up to provide maximum boost so they are most effective at high RPM's when there is lots of exhaust gasses.
So, the supercharger provides boost instantly and is operating at full capacity by about 1800 rpm. The air being drawn through the supercharger must go via the carby thus plenum thus intercooler thus turbos which pulls the air through the compressor wheel causing them to spool up faster (as the compressor and exhaust wheels are directly connected) thus resulting in a mechanical advantage. This means that the turbos are producing maximum boost earlier than they normally would by more easily overcoming their inertia. When the engine reaches its higher RPM's and the supercharger is beginning to become inefficient the turbos are operating at maximum and forcing the air into the supercharger allowing it to still operate at maximum efficiency.
The turbos are using energy and the supercharger is using energy this there is more gross energy being used but more power is made resulting in an overall net gain of more than each of the units could have provided on their own.
The reason for using low pressure from the turbos and the supercharger is that i am aiming to put as little stress on the components as possible for a few reasons.
1. The physical mechanical stress being less is less likely for things to break.
2. Lower pressures mean lower air temperatures meaning that more oxygen is actually getting into the chambers.
3. Dont want to break the engine just yet.
So, basically can anyone think of any issues that i am going to run into? I will list the ones that i have thought of so that you can add to them, discuss them or list new ones.
Issues:
- The height that the engine+charger+carby/s+plenum will go to
- Where and how to mount the intercooler
- How to reference the carby and what carby to use (blow through or draw through).
- rego issues
Please add whatever comments you like as the more people think about the more likely i can identify potential issues.
Cheers, Nathro.
p.s  Sorry for the long post but it is a little complex and hard to describe  :P
p.p.s Has anyone seen this done on a bedford before?
I don't have a signature
Re: My Bedford Idea - Twincharged V8.
« Reply #1 on: December 05, 2008, 11:55:51 AM »
The first question is WHY?
The Second question is WHY?
The Third question is WHY?
Having said that, is the van going to be a driver, a dragger, a shower or just a wet dream :D
If your doing it "Just because you can" then...well have fun, and I hope the money you pour into it is worth it.
I would say tuning would be your biggest issue, have you got a dyno handy ?
I'm not wanting to stifle your creative juices, but ask yourself, what use is it for, what sort of horsepower do I need, can I afford to build it, and then can I afford to run it.
Remember it's horses for courses, if it's to blow the doors of the "Mr Horsepower" guys at Summer Nats, then woohoo go for it, but if its to go do the shopping in, well maybe just the turbo's might do :D
« Reply #2 on: December 05, 2008, 12:21:27 PM »
sounds like a hell of a lot of work to produce 5-6 lbs of boost when a standard terracharger kit can produce 12-14 lbs .Just another thought , have you had a close look at ya bedford chassis?? it is actually pressed out of the same guage steel as the panels so it hasn't got great torsional strenght ( a worked six can twist them )So if you want this missle to go in a straight line it will need some work there.I personally would go with a vortex blower as it gives progressive boost over the rev range and are more energy efficient .I have one on a injected 13b rotary dirt dragger trike  it puts out 4-22 psi over the rev range producing 326 hp hope that helps
Offline booga
  • ahhh wind noise
« Reply #3 on: December 05, 2008, 12:33:45 PM »
this idea does sound like fun, i wont pick holes in it coz i do like the sound of your plan.
the only things i can think of off hand are
1. speed of the positive driven charger for over rev purposes eg when the twin turbos kick in will it want to go past where the charger can handle??
2. prob need positive pressure carb because if you want to run a draw thru you need turbos to go directly into plenum, may not have the same effect as running all your boost ( and air flow) through the carburettor.
3. look up a holden forum for any hq or similar for 235 engine mods. they have more room to toy with and are more likley to complete this idea.
other than that, have fun, sounds like a good project.
Offline nathro V2.0
  • i not a gumbie...
« Reply #4 on: December 05, 2008, 01:00:05 PM »
Thanks for the replies guys.  :)
It wont be a daily but i would like to be able to take it out on weekends etc. It should be fine for street driving unless i change the cam. It will just be a 'little' more lively.
I agree that it is a lot of work to go to for 8psi. The plan is to see if the whole setup will work. if it does work then i will consider rebulding a 308 and stroking it out to 355 with all the strong good bits and a lower compression ratio so that i can wind up the boost to however much i think it can take. Its just a matter of changing the springs in the wastegates (or using a boost controller) to make the turbos run more boost. Changing the S/C will just require a smaller pulley.
When the twin turbos kick in the amount of air will want to push past the c/s. Thats what the wastegate is on the plenum for. The s/c can only pump a set amount of air per revolution so if there is too much air coming in and not enough going out then the pressure will build in the plenum and the gate will open. Good thought though
The van itself i just want to be completely different from whatever anyone else has done. I figure this is just another step towards that. It wouldnt mind throwing it down the strip every now and again (if i can work up the courage) but mainly i just plan for it to go to shows and sunday driven.
cost of the setup shouldnt be too much. i plan on using secondhand parts etc just to see if it is viable and if that it can even be tuned using a carby. No point spending a ton of cash on new parts when there may be a massive flaw in my theory.  :P
I hadnt thought of the chassis strength. Thanks for the idea. But a lot of the guys on here are running rebuilt 350ci's that would be putting out at least 300hp. I dont think a 253 (even with 8psi of boost) will put out that much. Anyone on here running a big engine have issues with the chassis twisting? If so, what have you done to overcome this?
Cheers, nathan.
Offline booga
  • ahhh wind noise
« Reply #5 on: December 05, 2008, 09:12:03 PM »
this was on the net, thought it was abit relevant, you could do this to a six or a small v8 (so your twin turbos fit better) your 253 to keep the weight down and the revvs up..
http://www.turbophile.com/feature_cars/cameron_1200.html
sounds like it worked well and driveable.  good choice. fun. fun.
Ben
Brett
« Reply #6 on: December 06, 2008, 03:11:28 AM »
I heard theres a 253 with a twin turbo setup doing 8 seconds. Not in a bedford but. I dont see why not though.
Offline Joel Oswald
« Reply #7 on: December 08, 2008, 08:28:29 AM »
You'd have to make sure everything to do with the Drivetrain is solid as ever, as older stuff will pop before the chassis bends... And MASSIVE brakes to stop you, or even a parachute!!!  :)
Offline nathro V2.0
  • i not a gumbie...
« Reply #8 on: December 08, 2008, 05:08:57 PM »
Yeah i have thought about upgrading parts but i decided that i will just replace them as they go. Rather than shelling out heaps at once i will just replace them one at a time.
nathan.
Brett
« Reply #9 on: February 26, 2009, 04:53:28 AM »
Hows that project going Nathro?
