  • Dot Guests: 259
Author Topic: AIR CON  (Read 13225 times)
Offline ethyl
AIR CON
« on: June 08, 2013, 08:56:23 PM »
I am going to put air con in my truck but there doesn't seem to be much room for the condenser in front of radiator'
I have fitted a 202 injected and it has 3 row pullies on water pump and crank
has any one pics or description of air fitted?
Offline cords
Re: AIR CON
« Reply #1 on: June 14, 2013, 05:40:15 PM »
you could allways mpount it under the floor with a thermo fan on it thats how we do it rods with limited space  ;)
Cheers Gav
Re: AIR CON
« Reply #2 on: June 14, 2013, 06:07:48 PM »
Are you using all 3 rows on the pulley? I'm guessing one is for alternator and waterpump as standard, and another for aircon.
Swapping back to a double row pulley may well give you more room to move the radiator back toward the motor and put a condenser infront.
Are you running mechanical or electrical fans? Electrical fans are generally thinner than mechanical fans, there are a variety of options available..
Offline ethyl
Re: AIR CON
« Reply #3 on: June 15, 2013, 08:51:51 PM »
yes I was thinking this was best option
will be using all the pulleys, water pump, air con, alternator, power steer, hydraulic pump
I was think of using ford au electric fans but maybe tight so may mount them off to each side and fit ducting
just another thing to look forward to, lots of other bits to work on
Re: AIR CON
« Reply #4 on: June 15, 2013, 10:48:23 PM »
Ahh, I wasn't taking into account the power steering.
Just be aware, the AU fans are GREAT fans, much better than the VX fans I am using now which are also great. The only downside to the AU fans is that they draw alot of current. The EF/EL falcon fans are similarly good to the AU/BA fans, but draw less current. If you're using these fans on a remote condenser they will be on alot of the time, so you may need a larger alternator.
Just a thought
Re: AIR CON
« Reply #5 on: June 16, 2013, 11:08:02 AM »
Hey ethyl, can you post pics of your truck and it's air-con system. Over the years, there has been a lot of questions and debate about the best type and design of system to install in a beddy.
Offline ethyl
Re: AIR CON
« Reply #6 on: June 16, 2013, 08:18:24 PM »
Just a thought
I have all of those types laying around, been using Fords as work cars for about 13 yrs and I love spares and spare spares
so will check that out
Offline ethyl
Re: AIR CON
« Reply #7 on: June 16, 2013, 08:22:08 PM »
Will be few months yet, I only started fitting gear box (5 spd Tarago) yesterday and lot of other bits/mods to go
I have a few ideas and several choices of set ups I have collected over the years
Re: AIR CON
« Reply #8 on: August 08, 2013, 01:26:02 AM »
just a heads up, starting the air cond journey....picked up today 3 vintage air "trial' kits (basically empty evaporators). I'll post some pic's and info over the next cople of days......
the units are the "super", the "mini" and the "magnum" from vintage air.
www.vintageair.com
Re: AIR CON
« Reply #9 on: August 08, 2013, 09:05:15 AM »
Hey Dano, can't wait to see.
