  • Dot Guests: 274
Author Topic: painting and equipment advice needed.  (Read 20442 times)
Re: painting and equipment advice needed.
« Reply #40 on: January 09, 2009, 09:35:17 PM »
although runs are much easier to get rid of if your spraying in 2 pack...
how do u get rid of em Bren
razor scape then buff?
sand n buff?
Bren
« Reply #41 on: January 13, 2009, 02:25:02 PM »
definitely not that way :)
you can just sand them back using wet+dry and a block and then buff it.
Offline strez
« Reply #42 on: January 13, 2009, 10:14:06 PM »
use a titanium block  ;)
« Reply #43 on: January 14, 2009, 05:03:43 PM »
dont forget the criptonite paper ;D
razor scape, wet1000 n buff  has been the easiest ive ever used.
« Last Edit: January 14, 2009, 05:05:17 PM by marty »
« Reply #44 on: February 11, 2009, 06:30:40 PM »
hello people im back.... hope you all had a lovely xmass/newyear and perhaps a holiday.
i had a break over the holidays. back into it now but i had to sand the surface rust off  ;)
one question, i have started to lay down the undercoat (one section at a time as i fix small repairs) and i noticed in places it stands out a bit like sand or powder but is flat in others?
i know you have to sand the entire car before putting the color on but i was just wondering if its my technique that is causing the powder effect or is that just how primer looks before a wet sand and im just a big fat noob?
« Reply #45 on: February 11, 2009, 06:39:54 PM »
sounds like overspray - either paint mixed to thick or to thin - thick = big dust, thin = little dust
« Reply #46 on: February 11, 2009, 06:45:20 PM »
its a primer/filler
1-1 for primer
1-3/4 for filler
i went 1-1, 200ml undercoat and 200ml thinners.
« Reply #47 on: February 12, 2009, 06:22:40 AM »
what air pressure you using? and is your gun a high or low pressure spray gun?
Bren
« Reply #48 on: February 12, 2009, 09:53:56 AM »
yeah sounds like your gun isn't setup properly...
just play with it while painting on a scrap piece and you should be able to dial it in that way....
« Reply #49 on: February 16, 2009, 10:00:54 AM »
i painted a new panel and added a bit more thinners and i also payed more attention to gun distance and this panel came out smooth as a babies bum...
i think i was to far away from the panel and the paint was drying before they hit the metal...
i forgot to watch the gun and not the car ::)
