  • Dot Guests: 317
Author Topic: Finding bedford brakes  (Read 5378 times)
Offline Ivebinbit
« on: May 06, 2013, 06:55:25 PM »
Hi guys,
I've redone the old drum brakes ( cylinders, master, booster and lines) on my short wheel base and the stop me really well. There was enough meat on the shoes to last me a while, but I'd like to source a new set before I need them. Where can I find them in Sydney?
I'll have to get some pics up soon. I'm the only electrician I know working from a bebby.
Cheers chris
Re: Finding bedford brakes
« Reply #1 on: May 06, 2013, 07:53:54 PM »
Try berts brothers brakes , 118 fairfield street fairfield,
Pho - 96811188
« Reply #2 on: May 06, 2013, 08:52:14 PM »
Hey ivebinbit, my beddie was used by an electritian in tamworth for many years..he been retired for a few years now. the bedford had been sitting in a shed for ages...untill the family put her on ebay 2 yrs back.
just thought u may like to know  ;D
Offline ethyl
« Reply #3 on: May 07, 2013, 07:46:56 PM »
I think I have a new set of shoes in the shed some where and the ones I just took off to fit disks were OK if you want them.
I am assuming the CF truck is the same as the vans for brakes
Offline Ivebinbit
« Reply #4 on: May 07, 2013, 09:58:06 PM »
Thanks guys for the advise. Ethyl where abouts are you located?
Cheers Chris
Offline druid
« Reply #5 on: May 08, 2013, 08:21:12 PM »
I bought new ones about 3 years ago from the brake place down the road, you have to give them your old ones as a swap and let them know if you need them oversize to allow for machining. They re use the ones you give them for the next pair. I used central coast brake and clutch NSW They are in Gosford.
Offline ethyl
« Reply #6 on: May 08, 2013, 08:21:55 PM »
Cheers Chris
mt barker SA
Offline druid
« Reply #7 on: May 09, 2013, 01:22:35 PM »
Just spoke to the local brake place, they need to have the old ones to bond new linings to, 4 day turn around, let them know it the drums have been machined so they bond the right thickness linings.
« Reply #8 on: May 10, 2013, 10:27:59 AM »
Wouldn't hurt to get the drums machined as well.
Offline merlinsteve
« Reply #9 on: July 24, 2013, 08:48:48 AM »
I tried to source some replacement drums a year or so ago and came up empty. I ended up taking the drums to Darbys brake and clutch in Melbourne where they were machined oversize. They then made up oversize shoes to suit. Very good job and I am back to having a pedal that doesn't need pumping before using.
Maybe talk to your local brake place if you can't find any replacements.
Also I discovered that you can get some specially cast but that was about $1400 a pair.
Hope this helps.
if it isn't floored, I am bored
