  • Dot Guests: 283
Author Topic: New Lower wishbone arm bump stop rubbers  (Read 2591 times)
Offline druid
« on: May 03, 2013, 10:06:29 PM »
You may have to take your old one in to compare but the bump stop rubbers from a torana(not sure which model) will replace your old ones. They do however have 2 bolts protruding out of them, these fit nicely into the old spot and just need washers and nuts on the other side. This is a tougher rubber than the originals and stands a bit taller so I cut the top of the triangular section off to lower it.
