  • Dot Guests: 313
Author Topic: Engine cover  (Read 16675 times)
Offline Postie Bob
Engine cover
« on: April 15, 2013, 06:04:32 PM »
I,ve just got around to fitting the engine cover in my Bedmobile and noticed the dipstick and rocker  breather are touching the cover .
Looks like I need some major mods done to it . Should there be some sort of `gasket`between the floor and the cover? I,m thinking about chopping a hole in the cover for easier access to the dipstick anyhow .  How did you folk get around this prob?  ( I have a 186 installed ).
Cheers , Bob.
Re: Engine cover
« Reply #1 on: April 15, 2013, 06:10:15 PM »
They shouldnt be touching The breather should be at the front of the engine & the dipstick should have a curved piece at the top which faces foward to check the oil from the front Cheers Reid
Re: Engine cover
« Reply #2 on: April 15, 2013, 08:44:03 PM »
I have put some wing nuts on the engine cover- comes off in a few seconds. ;D And yes, I have a 186, black head etc.  works a treat.
Offline Postie Bob
Re: Engine cover
« Reply #3 on: April 16, 2013, 11:01:10 AM »
Thanks for the replies fella,s .
I meant where the hose attaches to the rocker cover at the back of the engine . Seems to be real close if not touching . I will have to bend the dipstick tube somewhat , at the moment it,s angled sideways towards the motor .
Re: Engine cover
« Reply #4 on: April 16, 2013, 12:18:16 PM »
Is this an original engine or one out of a car
Offline Postie Bob
Re: Engine cover
« Reply #5 on: April 16, 2013, 01:01:47 PM »
According to the engine number it,s from a HR Holden . Around the late 60,s I think .
Is it possible a later cover could solve the prob??
Offline kimbosound
Re: Engine cover
« Reply #6 on: April 16, 2013, 02:23:09 PM »
If your van had the old 4 cyl diesel when it was new, the hole in the floor will be slightly smaller and the holden 6 cyl engine will sit up hard
at the back end.....my truck was like that.....the engine covers both look the same but are slightly different. There should also
be a rubber gasket / seal glued to the floor.
Re: Engine cover
« Reply #7 on: April 16, 2013, 04:18:53 PM »
My 202 had 2 places to put the breather pipe I had mine in the front one just behind the filler But I got rid of it altogeather pluged the holes with rubber grommets & put a breather type filler lid on it works great Had a look today & there is only about 20mm gap between the back of the rocker cover & the engine cover
