  • Dot Guests: 162
Author Topic: reverse lights  (Read 4113 times)
Offline rhinodrum
reverse lights
« on: November 16, 2008, 01:32:39 PM »
Hi all, I just have a question about reverse lights in beddy's, if you need them for a RWC and if so what would be the best way to go about installing the lights and wiring, any advice wil help ;) thanks.
Re: reverse lights
« Reply #1 on: November 16, 2008, 02:14:21 PM »
You could wire into your indicators (flashing orange lights) or mount a spot white on the back (white) and wire to your gearstick.
On my custom van I am using a spot light with a toyota headlight motor it hide it when not in use, when you put it in reverse the spot light pops down and on, off and up when not in reverse - pros: is hidden out of the way. cons: more things to go wrong
Re: reverse lights
« Reply #2 on: November 16, 2008, 05:01:32 PM »
Hey man there should be a reverse switch on your manual gear box or for auto it will be part of the shifter which will switch to open when you engage reverse. So i would say run power from ignition to there then to either spot lights or the bedford indicators usually have a 2 way globe in them i think so one for indicator one for reverse.  ive been through 2 road worthys without having them.. but one man could refuse to pass it without it.. who knows..
« Last Edit: November 16, 2008, 07:52:14 PM by ben »
Re: reverse lights
« Reply #3 on: November 16, 2008, 08:30:44 PM »
For a really neat reversing light that reasonably matches a Bedford tail light, check out the Rinder models # 589 and # 864:
http://www.naauto.biz:8080/naauto/catalogue/category112/category115
Contact Details:
Neil Anderson Automotive
ph 02 60263391
It can be bought with (589), or without (864), a mounting bracket that has to be removed, and then it can be flush mounted. They look good and work well. A tip is to use 32cp light bulbs as they are a bit brighter than the common 21w bulbs.
Light and packaging:
Holes cut ready for fitting:
Fitted to van:
« Last Edit: November 16, 2008, 08:39:08 PM by BlackBedford »
