  • Dot Guests: 305
Author Topic: Bloody Diff  (Read 9700 times)
Offline THRILLS
Bloody Diff
« on: April 08, 2013, 08:07:44 PM »
Hey Guys
I'm up to the diff heartache
I have a swb cf 1975 with a 3.8lt v6 holden motor. Not sure what diff is currently on it but it's narrow.... Very narrow....
What are my options? Can I widen it? or do I need a whole new diff???? If so what diff would suit a 3.8lt v6 holden motor? diff ratio?
Anh shit.....
Thanks guys
Re: Bloody Diff
« Reply #1 on: April 08, 2013, 08:27:32 PM »
I'm running a 3.8 vy currently and i purchased my diff off Ben, she sits very well on 120 but i have no idea off the ratio - give Ben a ring or msg, tell him its the highway diff i bought off him a few years back.
Hope it helps.
Mezz
Offline THRILLS
Re: Bloody Diff
« Reply #2 on: April 08, 2013, 08:30:49 PM »
Thanks Mezz I'll give ben a shout tomorrow!
And how's the width? is it same width as front?
Thanks again!
Re: Bloody Diff
« Reply #3 on: April 09, 2013, 06:26:14 AM »
The original ratio for the V6 commodore is 3:08:1, you can stay with that or go to mid 3's, 3:5:1 or similar to allow for the aerodymanics of the CF
Re: Bloody Diff
« Reply #4 on: April 09, 2013, 08:25:10 AM »
This diff thing is not an easy fix Use the FORUM diff section Its all in there First of all what gearbox are you useing if it's the overdrive box that most V6 come with then you will need 3.5 to 4.0 would work best But if it's only 3 speed auto or 4 speed manual then 3.08 is the go The 3.08 is the easiest to get Most holden & ford use this ratio as standard so there are plenty around Second you wont find a diff that is as wide as the standard beddie they are the widest on the planit I dont know about F100 or old chev diffs but you need to go late model so you can get parts for then useing old stuff that you can get cheap is fals economy cant get parts & cost a fortune to repair The diff you have in there now sounds like a standard holden width If your handy with a welder or have deep pockets you could build a diff like mine which makes it 100mm wider useing standard parts then you have driveshaft problems I was lucky it bolted streight up Then there is break lines & handbreak cables different wheels Its all hard work you change one thing then you have to change 100 others If you are not handy with tools & dont know much about mechanics then you better get a second job Well enough of my ranting Beddies can be a lot of fun so best of luck Cheers Reid
Re: Bloody Diff
« Reply #5 on: April 09, 2013, 10:09:54 AM »
Hey THRILLS,
Are you after a holden studpattern or standard bedford
Studpattern highway diff?
For a LWB or SWB?
« Last Edit: April 09, 2013, 10:20:22 AM by mty »
Offline THRILLS
Re: Bloody Diff
« Reply #6 on: April 09, 2013, 02:09:18 PM »
Hey Mty
I have a short wheel base. And I have mags in both ford and Bedford stud pattern
Thanks
Re: Bloody Diff
« Reply #7 on: April 09, 2013, 02:46:40 PM »
Cool THRILLS,
Is the diff your after ford or bedford stud pattern
« Last Edit: April 09, 2013, 03:48:07 PM by mty »
Offline THRILLS
Re: Bloody Diff
« Reply #8 on: April 09, 2013, 03:21:15 PM »
Its the 5x114.3 ford stud parttern
Thanks
Re: Bloody Diff
« Reply #9 on: April 09, 2013, 05:04:58 PM »
The AU Falcon is the widest diff of all the late model cars I was going to use one stock width but it meant getting special offset wheels made so they would clear the rear springs & I didnt want to have special things made only wanted standard components so parts were easy to get The Holden parts are easyer to get & cheaper but the diff is not as wide so needed widening
