  • Dot Guests: 135
Author Topic: My Interior  (Read 11553 times)
Re: My Interior
« Reply #10 on: April 09, 2013, 02:58:45 PM »
Words of wisdom Hobbit ;) ;) ;D
Re: My Interior
« Reply #11 on: April 09, 2013, 08:08:11 PM »
verry tidy..will go there weekend....
Offline walzaher
Re: My Interior
« Reply #12 on: June 14, 2013, 08:28:50 PM »
Hi Hobbit,
Great job looks very nice! Did you use any of the PE foam on the walls of the van? im just trying to understand how u did it =)
Waseem
Offline Hobbit
Re: My Interior
« Reply #13 on: June 15, 2013, 05:15:56 AM »
G'day Waseem,
I used a contact adhesive to glue the PE foam and then the marine carpet to the walls.
Being able to spray the adhesive onto the surfaces is an advantage, however, a large paint roller works well too. I just cut everything to size and glued it on. The 10mm Formshield is also available with self-adhesive, but it is on the foam side, not the foil side. The 20mm foam I used has made my van
really quiet. A huge difference.
Offline Stew
Re: My Interior
« Reply #14 on: January 11, 2015, 07:59:57 PM »
Excellent work mae god inspiration to get stuck into mine
