  • Dot Guests: 260
Author Topic: yellow but not yella?  (Read 3649 times)
Offline Worzel
« on: November 11, 2008, 08:07:40 AM »
can anyone help?
I have a 186 that the previous owner tells me has a yella terra head. Can anyone tell me if it is so? (there is some yellow paint under the orange but y'know, yellow paint doesn't cost much.
along the head is cast 2811929 HOLDEN J177 7 H (the last H is in a circle )
hammers_spanners
Re: yellow but not yella?
« Reply #1 on: November 11, 2008, 04:20:17 PM »
Worzel look in the inlet ports, if the "cast" support has been removed and a thinner spacer fitted to improve air flow then it's most likely a Yella Terra. The H means High compression
« Reply #2 on: November 11, 2008, 05:15:16 PM »
Worzel, take the tapped cover off and have a look, if it has sqaure push rod holes double valve springs it may be a good chance it is. But the square push rod holds gives you a good idea. As for the yellow paint look under the yellow if there is any other paint other than yellow.  My ideas only could be wrong. Should have roller rockers as well.
Offline Worzel
« Reply #3 on: November 11, 2008, 08:21:41 PM »
Hmmmm, i was just gonna throw it in. has good compression. :-\
I have to change the sump and water pump, but what a pain - to take the starter motor off you have to take the extractors off, so i'll put a new one on when i put the trimatic on it.
« Reply #4 on: November 12, 2008, 06:11:51 AM »
Yep, did the same thing, new starter not worth the chance :D
