  • Dot Guests: 367
Author Topic: ROTTI'S VAN - BOOHAG  (Read 78914 times)
Re: ROTTI'S VAN - BOOHAG
« Reply #30 on: July 11, 2013, 08:18:20 PM »
Ok, think the NZ mount is a little different to this if I remember right, a lot better :D ( but could be wrong ) will take picture and upload tomorrow, I think a engineer could make this up cheap, it was the idea behind it I am talking about.
« Last Edit: July 11, 2013, 08:22:21 PM by Bas / NZ »
Offline Rotti
« Reply #31 on: July 11, 2013, 08:21:25 PM »
your a legend, cheers! :)
« Reply #32 on: July 12, 2013, 07:11:40 AM »
Offline Marky
« Reply #33 on: July 12, 2013, 04:46:31 PM »
have been throught this scenario a few times...w diffs....
seems CFS's had wider spring width than CFL....
n with a lots of vans... having shorter width diffs..
ive had CFS vans with shock mounts on both sides of chassis...
ah........ ::) the The world non standardised bedfording..
Hope u get it sorted Rotti...
Gotta get a QLD NNSW Beddy run happning soon as
Creative Media Producer
Offline Rotti
« Reply #34 on: July 12, 2013, 06:26:04 PM »
Baz-, cheers for those pics, there is some difference between yours & the one that Rumax uploaded. With my diff being under the springs, maybe the ones with added angled/stepped bracket is what im after? ???
Marky-, what if I found some top mounts from a van that mounted on the inside of the chassis & had them welded on, would that probably be my best solution, or, do you know if these jumbo style bottom bracket may work? got a pair I can try out?
« Reply #35 on: July 12, 2013, 07:13:53 PM »
I have seen the Jumbo ones fitted to a SWB  under the diff  housing as the spring sits on top, worked a treat, not sure on the set up as can't remember, it was a few years ago.
« Reply #36 on: July 12, 2013, 07:16:03 PM »
Thanks for the pics Bas. Cheers Gordon
Offline Rotti
« Reply #37 on: July 19, 2013, 08:40:15 PM »
Well, over the last couple a weeks, I've stripped down BOOHAG naked & have been givin' er a good full body massage, upgraded the hq 2 core rad to a v8 size 3 core...JUST fits!, well it doesn't really if you put a thermo fan up front. Deleted the mech fan, fitted the thermo & modified the grill panel to hide the thermo, works nice.
No windows in the rear anymore, including rear doors, cut up a couple of bens fibreglass fill in panels for those!
She wont be perfect, but a good freshen up, nice new satin black, peep mirrors, WURTH parking sensor kit, rear camera GPS setup from the states...think that's it ;)
Offline Rotti
« Reply #38 on: July 19, 2013, 08:43:38 PM »
sorry for the doubleup pic, was supposed to be this one! :-\
Offline Rotti
« Reply #39 on: July 22, 2013, 06:10:13 PM »
Got the mirrors this week, 4" peep with 1" arm extension. LED turn signals incorporated in glass, these with backup camera, &  reversing sensors should keep the better half happy!
