  • Dot Guests: 319
Author Topic: bedford diff  (Read 7916 times)
Offline tiwaz_nz
bedford diff
« on: March 10, 2013, 08:58:57 AM »
i have a diff off my 79 swb and am thinking about putting on trade me ..
its a 3.75/1 .. whats its worth ... or what should i be hoping for  ??? ???
Re: bedford diff
« Reply #1 on: March 10, 2013, 04:20:05 PM »
Very limited market for them. I sold my Cresta diff around 2 years ago now I think. I can't remember whether I got 2 or 3 hundred dollars for it. It was a word of mouth sale and not on Trademe though.
Offline Sundownernz
Re: bedford diff
« Reply #2 on: March 11, 2013, 08:36:56 AM »
One of our members might be after a diff and he'll be comin down to the Nationals. I'll let him know and maybe you can do a deal.
Garry.
Offline tiwaz_nz
Re: bedford diff
« Reply #3 on: March 11, 2013, 05:35:51 PM »
one of RCV wanted it ... but not heard from him in a while ...
changing a diff after a few drinks sounds like a great idea ...  ;D
Offline TheArchiTech
Re: bedford diff
« Reply #4 on: April 03, 2013, 06:22:07 PM »
HI Man, what ratio is it, has it got the cresta pinion gear in it. My spider gears have packed up I have a cresta pinion gear in mine.
I just bought another one and put it in on the weekend but it was stuffed.
Offline tiwaz_nz
Re: bedford diff
« Reply #5 on: April 03, 2013, 07:01:30 PM »
ratio is 3.75 .. havent opened it so not sure if its a cresta one ... but with that ratio and in a standard beddy housing what elsr could it be
to check ratio i marked the drive shaft end and turned the drive wheel 2 turns ... count the amout of times the shaft turns
have told someone in the weekend ill hold it for them ... but not planing on waiting for ever
wheel bearing on passenger side is very noisy .... failed wof becourse of it ...
« Last Edit: April 03, 2013, 07:03:42 PM by tiwaz_nz »
Re: bedford diff
« Reply #6 on: April 03, 2013, 07:19:24 PM »
bugger about the wheel bearing as they are really expensive to replace.. My email is archdraught@gmail.com, keep in touch in regards to whether the other guys wants it or not.
Cheers Phil
Re: bedford diff
« Reply #7 on: April 04, 2013, 05:22:14 AM »
Phil, i'll ask around today, i don't have any though.
You don't need to pull diff head out to tell if it's a cresta or not, crestas have a longer snout, about 2 inches longer
Re: bedford diff
« Reply #8 on: April 04, 2013, 05:37:52 AM »
Yep that 2" makes a big difference. ;)
Re: bedford diff
« Reply #9 on: April 04, 2013, 05:50:49 AM »
yep, that 2 inches can make her stop screaming
at 80k's
