  • Dot Guests: 382
Author Topic: Rear wheel cylinder Q  (Read 3921 times)
Offline Postie Bob
« on: February 15, 2013, 02:28:05 PM »
I,m working on my rear brakes and have hit a bit of a hurdle.
Am replacing the wheel cylinders with Mini ones but the small pins on the back of the new cylinders don,t quite line up with the holes in the backing plate.
Are those pins necessary ? What is their purpose ? Do I slightly modify the backing plate or just cut off the pins  :-\ .
The Mini cyl,s only have an inlet port and a bleeder . I put a tee-piece in the line between the 2 cylinders and connected the flexible hose to it .
I now have a bleeder at both wheels . This shouldn,t be any drama should it ?
Cheers , Bob.
Re: Rear wheel cylinder Q
« Reply #1 on: February 15, 2013, 02:51:19 PM »
Strange, the Mini cyl I got fit perfet, no need for any changes, do you whant a part number.......
Offline Postie Bob
« Reply #2 on: February 16, 2013, 08:55:33 AM »
Hi.
Thanks for the reply . A part number would be good . The ones I,ve got suit a Mini Cooper , got a number 4411 on the box .
Did you have to change your brake lines or did you have a cyl with an inlet and outlet port ?
What is the trick to getting the e-clip on ?  When I pulled my brakes apart they were missing . The cylinders must have been just floating around in there!!
Cheers , Bob.
Offline slikgm
  • Nothing is straightforward on a Beddie!
« Reply #3 on: February 16, 2013, 08:58:31 AM »
I drilled the a new hole in the backing plate ,And yes its better to have a bleeder on both sides thats the difference between early and later model drums.
« Reply #4 on: February 16, 2013, 10:00:21 AM »
Ok part number on the box is 4241-075 Rear Wheel Cylinder then NZ-2076 Brand: KS Hydraulic Parts, there are Mini, but not sure what model, but has inlet and bleed. Clips just slip / push into the grove around the bottom of the inlet, cylinder must be pushed right in for grove to be visable on back of backing plate, a little force needed.
« Last Edit: February 16, 2013, 10:11:10 AM by Bas / NZ »
Offline Postie Bob
« Reply #5 on: February 16, 2013, 10:38:54 AM »
Thanks mate.
I just noticed on the box ( under a sticker )  the number 4241396 so must be slightly different . They will fit ok with a little file work though .
Cheers.
« Reply #6 on: February 16, 2013, 03:33:32 PM »
only difference is they have a smaller bore.
 ive used mini ones for 10+years with no problems.
Offline tiwaz_nz
« Reply #7 on: February 16, 2013, 05:28:18 PM »
mine are different from the mini ones
just added pics of mine to my gallery
« Reply #8 on: February 16, 2013, 06:01:47 PM »
Those are off the 10" drum, the mini ones replace them, just need to file / cut a little of the shoe mounting point on thr backing plate as no longer need as cylinders have a shoe locator on them..
