  • Dot Guests: 349
Author Topic: 202 engine position  (Read 3590 times)
Offline alice
202 engine position
« on: February 11, 2013, 09:55:53 AM »
hi peoples....i'm just about to measure up my tailshaft to be cut and balanced,but before i do that i realised that i didnt take note of what position(height)the engine should be.i moved it around alot getting my 5speed in position.i measured from the top of the rocker cover to the floor of van is 17.5cm(right where the bell housing is)i think thats a bit high....
anyone got any ideas?
cheers alice.
Offline ethyl
Re: 202 engine position
« Reply #1 on: February 11, 2013, 07:31:56 PM »
the engine position shouldn't change, unless you moved the engine mounts
I assume it's toyota 5 speed
I have put celica boxes in Toranas and the diff between Aussie 4/3 speed and toyota tail shaft length is about 30mm
so would expect Bedford shaft to need shortenning the same
can check if it helps
Offline alice
« Reply #2 on: February 12, 2013, 04:55:48 PM »
thanks..i went to see a friend that has the same set up as me and saw that the xmember had been lowered an inch,which was all i needed to know.all done and fitted,just having the tail shaft done as we speak....not long to go till shes on the road!!!!
