  • Dot Guests: 383
Author Topic: wanted: bridgestone sf-330 245 / 50's profile  (Read 10129 times)
« on: November 03, 2008, 01:00:01 PM »
looking for 1 or 2 of. (already have 1)
wanted: bridgestone sf-330 245 / 50's profile white wall tyres
i think you can still get these new for $350 a pop!
but its a waste when my camber is outa wak anyway and dont plan on fixing it for a while.
Offline Worzel
Re: wanted: bridgestone sf-330 245 / 50's profile
« Reply #1 on: November 04, 2008, 12:04:35 PM »
sound like the easy way would be to fix it rather than replace the tires every 6 months ???
« Reply #2 on: November 04, 2008, 03:46:47 PM »
its not broken as such.. my springs are sagged like most 35 year old springs.. so the front end sits down a bit. it looks good.but the camber is out.. because the lack of adjustment on our beloved bedfords..
if i bring the front up it will look silly. im hangen out for craig to work out a way to add camber control to the beddy front end!! then it will be all sweet!!
Tweaker
« Reply #3 on: November 04, 2008, 09:03:54 PM »
Hey Ben, how bout fixing your springs and throwing on one of your front spoilers and a set of flares to make up for the height and save yourself a fortune in tyres ;)
Maybe my front is saged also cause I couldn't emagine lowering my front end much more cause it'd hit everything........ :o
« Reply #4 on: November 04, 2008, 09:35:35 PM »
hmm could but id have to fix the back sagged springs also!!!!
hmmmm
Tweaker
« Reply #5 on: November 05, 2008, 12:04:09 AM »
hmmmm
Yeah me too. I've only got about 2" of clearance before I hit my Bump Stops
« Reply #6 on: November 05, 2008, 07:15:55 AM »
yeh i bet you never hit the bump stops thou.. those lwb springs are tough as!!!!!!!
Tweaker
« Reply #7 on: November 05, 2008, 01:20:04 PM »
Actually, I've had that much weight in the back that the bracket holding my break line to my diff has cut a hole through the floor! ::) I was actually driving on the bump stops and everytime I hit a bump the entire back end would leave the ground. :P It made for an interesting drive!
« Reply #8 on: November 05, 2008, 04:37:36 PM »
Damn man what were you carrying? Sounds like something heavy;)
Tweaker
« Reply #9 on: November 05, 2008, 06:35:02 PM »
An entire event's lighting equipment ;) Hehe ;D
I carried over 1Ton of scaff in my SWB to and from a gig in Byron 1 time. Had the rear springs inverted! That van rocked! It had a highway diff, trimatic and low compression 202. It drove like a snail till you got it's speed up then it would (and wanted to) crooz along at 140k for hours no dramas, and it drove like this wether it was empty or full, made no difference! Loved that van!
