  • Dot Guests: 351
Author Topic: Mirrors  (Read 8211 times)
Mirrors
« on: January 21, 2013, 09:03:21 AM »
Hi guys. I need to get some mirrors for my van but after a week of looking around I cant really decide. I need them to be large and practicable as eventually the van will be using for towing a 4.6M boat.
The options so far are your usual ford style swing away mirror:
Or the swing away bracket with a large tripod head fitted:
Or go all out and fit the tripod with the large head:
With the tripod the head can swing in for normal use and then swing out for when towing.
What do you guys and girls think?
Offline Vandee
Re: Mirrors
« Reply #1 on: January 21, 2013, 09:12:04 AM »
Shane, think you have answered your own question, No 2, No 1 look good but not pratical for your use, and due to the angle of the Bedford door No 1 needs to be changed a little as standard ajustment for viewing is not that great.
Re: Mirrors
« Reply #2 on: January 21, 2013, 09:17:21 AM »
what ever way you go just remember that if you are going to swing the cargo door around too where it contacts the passengers door will you  need a closer fitting mirror there as per standard
Good luck with the search, ;D I looked around and went back to standard mirrors with a reversing camera 8)
Offline Vandee
Re: Mirrors
« Reply #3 on: January 21, 2013, 11:19:52 AM »
Could always head back to the old west coast mirrors, I thnk you guys call them.
http://www.exploroz.com/Forum/Topic/82821/Aussie_Truck_Mirrors.aspx
« Last Edit: January 21, 2013, 11:22:03 AM by Vandee »
Re: Mirrors
« Reply #4 on: January 21, 2013, 12:28:35 PM »
I have looked at the jr west coast mirrors but I'm not sure about drilling holes into the upper door frame.
Can you get replacement arm/brackets like standard on the bedford? I can find them anywhere. If I could get new ones I would probably be happy with mirrors like these ones:
They should be large enough.
« Last Edit: January 21, 2013, 12:47:40 PM by ShaneJ »
Re: Mirrors
« Reply #5 on: January 21, 2013, 12:46:57 PM »
I found these arms:
Could possibly use with a mirror like this:
Offline maicoletta
  • Beddy til I die!!
Re: Mirrors
« Reply #6 on: January 21, 2013, 09:24:53 PM »
the standards just bounce around too much    ::) ::)
tripod style wouldnt suit me, reckon i'd have trouble in narrow car spots around here    :o :o
and i've a CFL, so think i need a decent size mirror, so...
I'll be whacking on West coasties when I get a chance!  8)
not the juniors tho, the squarer type, similar to the top pair on the exploreoz page there
Re: Mirrors
« Reply #7 on: January 21, 2013, 09:28:03 PM »
I think I have decided to go the chev van mirrors. The mirror head is 9 and 3/4 x 7" which is a pretty good size. They look pretty sexy also. And... the mirror head can be replaced with this:
Offline Brendeni
Re: Mirrors
« Reply #8 on: January 22, 2013, 06:41:31 AM »
I am using the West coast Mini Truck mirrors. Having said that. The beddie has not left the garage for a road test. Still other work to be done before then.
I like the look of the mirrors however i think that it would need blind spot mirrors to be attached as the curve of the mirror can be a bit deceiving.
Brendon
Re: Mirrors
« Reply #9 on: January 22, 2013, 09:02:17 AM »
Here you go shane, why not a set of F350 Super duty mirrors, when you want to tow your boat, you hit a switch and the mirrors extend to suit, when your finished they retract back to a normal mirror.
