  • Dot Guests: 363
Author Topic: Front wheel cyl  (Read 3921 times)
Offline Postie Bob
Front wheel cyl
« on: January 09, 2013, 03:51:03 PM »
Hi.
Just pulled my front brakes apart and they need a complete o/haul.
Can someone point me in the right direction for cylinder repair kits ( or complete cylinder ) .
I,ve been searching my PC till I get a head spin but seems to be a hellova difference in parts and price .
Any help would be much appreciated.
Cheers,  Bob.
Re: Front wheel cyl
« Reply #1 on: January 09, 2013, 06:16:51 PM »
guys at better brakes in moorabin did mine - i'm sure its a franchise so look em up in your area, guys were really helpful and did a great job.
Offline Postie Bob
Re: Front wheel cyl
« Reply #2 on: January 11, 2013, 04:25:09 PM »
Thanks mezzmo.
Better brakes are not in my area. I can get new cylinders ( $45 ea ) but need to know if there the right ones .
Are part numbers  P5923 & P5924 the correct ones for my `74 ?
Cheers, Bob
PS... still looking for a replacement master cylinder.
Offline Vandee
Re: Front wheel cyl
« Reply #3 on: January 11, 2013, 05:45:31 PM »
I used Mini wheel cylinders they are the same
Offline Postie Bob
Re: Front wheel cyl
« Reply #4 on: January 13, 2013, 03:01:01 PM »
Thanks Vandee.
I will chase that up.
Are the rear brake cylinders the same?
Cheers ,Bob.
Offline Vandee
Re: Front wheel cyl
« Reply #5 on: January 13, 2013, 06:18:21 PM »
Yes if you are using the same size drum, anyway both are mini units. Will look today and post part number
Offline Postie Bob
Re: Front wheel cyl
« Reply #6 on: January 30, 2013, 08:43:46 PM »
Got my mini wheel cylinders all fitted up . Ta for the info .
Half the cost to  :) .
Had to use a file on the backing plate holes though ( they didn,t quite line up ) .
Now have to attack the rear brakes . Hopefully there mini cylinders to .
I,m still after a r/h  door lock assembly if anyone has one to sell .
Cheers, Bob.
