  • Dot Guests: 232
Author Topic: Give me a brake  (Read 7962 times)
Offline Postie Bob
Re: Give me a brake
« Reply #10 on: January 31, 2013, 09:37:48 PM »
Have just about got my master cylinder drama sorted out but my replacement cyl has a sloping reservoir and my original has a round one .
Is the booster the same for both types of  cylinders or do I need a matching one?
I need to rotate the booster 90* for the sloping cyl to fit my booster but how about the pushrod length, etc ? is that a prob?
Cheers , Bob.
Re: Give me a brake
« Reply #11 on: January 31, 2013, 09:53:44 PM »
i think there are a few posts in the arkives regarding this, do a search or maybe someone could bump the info up to the top?
Re: Give me a brake
« Reply #12 on: February 01, 2013, 07:00:30 AM »
Have you checked weather the bonnet will close with that reservoir just saying
Offline Hobbit
Re: Give me a brake
« Reply #13 on: February 01, 2013, 04:46:04 PM »
It's sweet Reid, Bob's got my old Bedford master cylinder, no probs for fit. I'd say the later ones must
have had a horizontal mounting (flange) and the earlier ones were vertical.
As Bob said, rotating the booster is the only solution.
Offline cfjeff
Re: Give me a brake
« Reply #14 on: February 04, 2013, 06:15:49 PM »
you definatley want the sloping master as opposed to the round one, reason is the pistons in the round one are linked by a crappy wire that often breaks, resulting in a trip to the resleever. These were only used on beddys for a couple of years, and also were used on triumph cars. Boosters were the same just rotated so far as I'm aware.
Cheers Jeff
Just customize it!
Offline tiwaz_nz
Re: Give me a brake
« Reply #15 on: February 04, 2013, 06:28:18 PM »
jeff .... what year or years had the round master with only one outlet ?
Offline cfjeff
Re: Give me a brake
« Reply #16 on: February 04, 2013, 07:15:58 PM »
The round with only one outlet were the early ones, 70,to 72/73 I think. Round dual outlet ran from 75 to somewhere in 77, from there on were the lockheed triangle ones. These are the ones you want according to the resleeve guys I use here in christchurch.
Cheers Jeff
Just customize it!
