  • Dot Guests: 302
Author Topic: Rear brakes lock before front  (Read 11785 times)
Re: Rear brakes lock before front
« Reply #10 on: January 03, 2013, 05:45:38 PM »
G'Day Shane just a thought here but you have got the master plumbed up right ? the port with the larger reservoir is always the front brake ,if plumbed backwards the load proportioning spring inbetween the plungers will activate the rears first . also if the galaxy caliper has a larger piston than the falcon will cause the same problem (larger surface area on piston =less hydraulic effort)   hope this helps   Cheers Merlin
Offline Marky
« Reply #11 on: January 08, 2013, 09:03:01 AM »
Hey dano
The Advice i got from Wayne..
was straight out his Memory Banks...he diagnosed it over the phone
and was able to supply me with the wheel cylinders....
mine went from
HQ size
(FR/disc..Rear/Drums)
...down to
HD (drums all-round)
Creative Media Producer
