  • Dot Guests: 279
Author Topic: Engine mounts  (Read 5220 times)
Re: Engine mounts
« Reply #10 on: December 05, 2012, 07:23:40 AM »
i forgot to say you'll also need to change the pickup.. so make sure you get one with the sump..
Offline cfjeff
Re: Engine mounts
« Reply #11 on: December 06, 2012, 06:32:26 PM »
Gidday I also had this problem with my sump on my 186. Mine was resting on the steering rack, so to get more clearance I loosened the engine mount bolts to the block, jacked up the motor and tightened them. This gave me a few mils clearance, so i next said bugger it and proceeded to indnet the bottom of the sump a bit with a block of wood and hammer. Now have about 7 or 8 mils clearance above the rack.
Cheers Jeff
Just customize it!
