  • Dot Guests: 289
Author Topic: Camper Update  (Read 223336 times)
Offline Marky
Re: Camper Update
« Reply #310 on: January 02, 2013, 05:57:23 PM »
bit late but...."you got to be Joking Reid"
lucky son to have a dad like you.... ;D
Creative Media Producer
Re: Camper Update
« Reply #311 on: February 11, 2013, 05:56:04 PM »
Well guys & girls Im still a beddie owner it went to $6.200 in the auction & the bidder offered me $7.500 SO im keepin it so I guess the spendin starts again What to do next
Re: Camper Update
« Reply #312 on: February 13, 2013, 10:17:42 AM »
i think..(unusual) maybe the universe is telling you to hang on to it reid   ;)
Re: Camper Update
« Reply #313 on: February 19, 2013, 01:50:05 PM »
Well guyes & girls Getting motorvated again got the partition for the shower when the poptop is up finished The foam tube around the edge makes a tight fit & prevents the ply from cutting into the hood lineing Last photo is from the inside
Re: Camper Update
« Reply #314 on: May 06, 2013, 03:58:10 PM »
well Guys & Girls got a bit more done Glued the 5mm insulation under the engine cover {bitch of a job} & also made a new carby hat as the old puddin dish was too big & was hittin the engine cover All done now & is quiet as a mouse inside Cheers Reid
Re: Camper Update
« Reply #315 on: May 06, 2013, 07:59:00 PM »
Does that mean your in big trouble when your missus is cookin puddin?
Re: Camper Update
« Reply #316 on: May 06, 2013, 08:16:22 PM »
Not much good for cookin now got a big hole in it haha
Re: Camper Update
« Reply #317 on: May 30, 2013, 05:06:40 PM »
Well been doing a bit more on the camper as I have said somewhere else I have been having a bit of trouble with the ignition switch Pulled it apart very carefully as there are a few springs & ball bearings in there & gave it a good clean as there was a heap of gunk in it Cleaned up all the posts inside The start post was just about worn away that's why it was hard to stars sometimes so decided to install a start button in the dash wired it into the loom & now can start with either key or button Cheers Reid
Offline walzaher
Re: Camper Update
« Reply #318 on: May 30, 2013, 05:24:19 PM »
restoreid why would you sell it though in the first place? it looks so nice from the inside! what did u use to line the inside engine hood? do u recommend it?
Waseem
Re: Camper Update
« Reply #319 on: May 30, 2013, 06:29:21 PM »
Waseem I got it from Clark Rubber it is 5mm thick & designed for the job It comes with either preglued with peeloff backing or nonglued which I used so far it's great keeps the heat & noise out with all the dynomat on the floor it's quiet as inside Got new rubber backed carpet the other day will cut it in next week will be great inside then Then only the door trims to doo
