  • Dot Guests: 282
Author Topic: Camper Update  (Read 198052 times)
Re: Camper Update
« Reply #260 on: December 09, 2011, 02:52:39 PM »
Hi guys Well got a bit more done this week sprayed underbody sealer where the tank goes & sprayed the tank & strapped it up under All finished now
Re: Camper Update
« Reply #261 on: December 09, 2011, 02:55:35 PM »
Installed a couple LED lights above the beds will be good for reading & shine on the table
Re: Camper Update
« Reply #262 on: December 09, 2011, 03:04:16 PM »
Now a tricky one for all beddiefiles out there I found this plate under the rear passenger wheel well pop riverted to the inside of the wheel tub The letters & numbers are welded with a stick welder ( thought it might have something to do with it being a camper but Im not sure Have a look under yours & see if there is one  Any Idears come on Ben youve pulled a few apart I bet I get a few weird surgestions HaHa
Offline JOE RYAN
Re: Camper Update
« Reply #263 on: December 09, 2011, 05:24:31 PM »
I have a similar plate on my 76 camper that has been welded over the original chassie number on the passenger side firewall, when I asked Qld Transport about it they advised that the stamped original number was difficult to read as the numbers were not stamped in very deep and there was some discussion if a digit was a C or O. So as a solution the Qld Transport issued a new number on a steel plate that they supplied and the owner had to weld on but my number is stamped into the plate not welded like yours.
Joe
Re: Camper Update
« Reply #264 on: December 09, 2011, 08:33:11 PM »
qld transport oh my:(
never seen it done with a stick welder man you can get away with anything on old cars
Re: Camper Update
« Reply #265 on: December 10, 2011, 09:41:47 AM »
if the rego branch don't reconise the chassis number, they will allocate one to the van, car or bike. A lot were done with a stick, straight to the chassis. Then in their superior wisdome, thet would let you fix it by poprivets, self tappets etc. Or it could just be the number for the camper alone
Re: Camper Update
« Reply #266 on: January 10, 2012, 01:55:27 PM »
well guys got another one off those mungrel jobs done Slowley getting it finished Picks are better than words so hear's a few
Re: Camper Update
« Reply #267 on: January 10, 2012, 01:58:33 PM »
As you can see this is my heat exchanger in the exaust system before wrapping Here is some after
Re: Camper Update
« Reply #268 on: January 10, 2012, 02:02:54 PM »
Here it is installed & hooked up to the 80ltr alloy tank under bed Hope it will thermo sifen & heat the water just a bit for shower after a days touring Cheers Reid
Re: Camper Update
« Reply #269 on: January 11, 2012, 04:54:45 AM »
That's pretty tricky utilising the heat from the exhaust system like that. I'm just trying to keep as much heat in the pipes as possible and to stop it radiating out as due to the mid-mount location of the engine in mine I have a bit of a heat trap under the engine cover and the air intake is going to run just a bit too close to the exhaust for my liking. Going to heat wrap the pipes and I think I'll be implementing some kind of heatshielding for the intake as well.
