  • Dot Guests: 287
Author Topic: Camper Update  (Read 198734 times)
Re: Camper Update
« Reply #180 on: February 28, 2011, 05:38:41 PM »
Well guys I got a heap more done this week finished machining the hubs drilled & tapped the caliper brackets & trial fitted it all up needed 4mm spacer between the caliper & the plate to center the caliper up on the disc is all done & painted & will install tomorrow sorry no pics here their in my gallery Will get some more as I fit them up Cheers Reid
Re: Camper Update
« Reply #181 on: March 01, 2011, 04:23:36 PM »
Had a good day finally starting to piece it togeather Photos worth a 1000 words
Re: Camper Update
« Reply #182 on: March 01, 2011, 04:24:15 PM »
Some more
Re: Camper Update
« Reply #183 on: March 01, 2011, 04:25:38 PM »
OOps
Re: Camper Update
« Reply #184 on: March 01, 2011, 04:28:37 PM »
And some more only have to fit brake hose & make grease cap & job done Cheers Reid
Re: Camper Update
« Reply #185 on: March 04, 2011, 09:50:27 AM »
nice work bud, top job!!! 8)
thanks for the pics
Re: Camper Update
« Reply #186 on: March 06, 2011, 07:59:18 PM »
Hi guys I would like some help from those that have fitted disc brakes & kept the original bedford master cylinder Is there non return valves in the master cylinder to hold pressure in the line for drum brakes & did you remove them for the discs Im going to leave the beddie one on for now but will change to xb falcon later Any info would be greatfully receved Cheers Reid
Offline Jeff
Re: Camper Update
« Reply #187 on: March 07, 2011, 03:27:32 AM »
I fitted discs to my last Cf and used the original master cylinder.
Had no problems at all, although I *think* the disc brake model ( CF2 ) has something extra fitted to the system.
Funny old life.
Re: Camper Update
« Reply #188 on: March 07, 2011, 08:21:57 AM »
i drove around with disc brakes for some time with orig master.. not advised thou. front brakes were sqeeking cause of the line presure and the proportion is wrong between front and back.
just change the master cylinder. makes it much easier and its not a big job.
Re: Camper Update
« Reply #189 on: March 07, 2011, 09:05:56 AM »
What do suggest as a replacement master benny.
