  • Dot Guests: 194
Author Topic: Camper Update  (Read 223788 times)
Re: Camper Update
« Reply #140 on: August 05, 2010, 04:52:38 PM »
Cutting the discs off the hubs with angle grinder Yes Ben I was real careful
Re: Camper Update
« Reply #141 on: August 05, 2010, 04:54:55 PM »
Now the machining starts to get the hats to fit the hubs
Re: Camper Update
« Reply #142 on: August 05, 2010, 04:58:06 PM »
I have already got the new bearings & seals for the hubs Only got to get steel plates for caliper bracketsw will post more as I get it done Cheers Reid
Re: Camper Update
« Reply #143 on: August 05, 2010, 07:08:03 PM »
well that looks interesting
Re: Camper Update
« Reply #144 on: August 05, 2010, 08:01:42 PM »
Also got the diff sorted it's a VS commie disc brake which we are going to a LONG axle in the short side which makes it 1660 OA Should make it long enough
Re: Camper Update
« Reply #145 on: August 05, 2010, 09:06:57 PM »
its a good idea that one. how you gunna keep it straight when you weld it? or will you pull it straight later?
Re: Camper Update
« Reply #146 on: August 06, 2010, 07:46:08 AM »
Machine it square & pull it together with a long length of boocker rod & we have another axel with 3rollers spotted on it & check it with machine blue & heat &shrink were necessary
Re: Camper Update
« Reply #147 on: August 15, 2010, 03:03:42 PM »
Here you are John the difference between VH & VX discs
Re: Camper Update
« Reply #148 on: August 15, 2010, 03:06:28 PM »
Have had 1 hub turned down to fit inside VX disc hat for mock up purposes
Re: Camper Update
« Reply #149 on: August 15, 2010, 03:10:12 PM »
Made a template out of masonite for the caliper bracket
