  • Dot Guests: 330
Author Topic: motor change..  (Read 12334 times)
motor change..
« on: October 02, 2008, 10:19:40 PM »
here are a couple of pics of me pulling out 253 out of cream van..
back on the ground thank god!!
doofhard
Re: motor change..
« Reply #1 on: October 02, 2008, 10:28:50 PM »
Safe as houses
doofhard
Re: motor change..
« Reply #2 on: October 02, 2008, 10:29:19 PM »
love your work Ben
Offline Jock
Re: motor change..
« Reply #3 on: October 02, 2008, 11:14:07 PM »
That's the way u huh u huh I like it u huh u huh that's the way.....
Like your work brother! Hoist her up, wheel her out and voila! hahahaha
Re: motor change..
« Reply #4 on: October 03, 2008, 04:39:12 AM »
wow, u dont muck around do u ben, :)
great job ,
marty
Re: motor change..
« Reply #5 on: October 03, 2008, 05:32:41 AM »
hy doofhard.. wouldnt get under there like that ay.. just get it out and run.. lol
Re: motor change..
« Reply #6 on: October 03, 2008, 08:22:56 AM »
G'day Ben
I suggest that you should build a couple of tools to make life easier, and safer for you and the Bedfords!
A trolley to roll the motor and gearbox out. I posted plans on the old forum.
The body can be lifted safely from underneath behind the front doors. A frame can be easily welded up to achieve this. No scratches or dents on the CF or you.
Re: motor change..
« Reply #7 on: October 03, 2008, 10:12:03 AM »
I agree Chris safety is important.
I have seen your ideas for the engine and that is excellent.
As for the frame for lifting the van from behind the front doors, could you give us a sketch of what your suggesting.
I would have thought a gantry would be a good investment and simple to build, but your idea may be smaller cheaper and easier.
Offline atk1
Re: motor change..
« Reply #8 on: October 03, 2008, 10:29:11 AM »
Hi Chris, could u please re-post your plans on this forum? Im gonna do a motor swap ASAP and this would help me alot. I saw pictures of the trolley but dimensions would be great. Do u have pictures/plans of the lifting frame?
Thanks
Watson
Re: motor change..
« Reply #9 on: October 03, 2008, 11:29:39 AM »
G day all
the easyest way to do this, is with a 2 post hoist. make it a lot safer & less head & back acks.
there is nothing in your way just roll the hole lot out & back in.
but if not i have used 2 hi lift jacks & 2 hi stands.
matt has used 1 engine crane to lift the body of the front end then put 2 stands under it.
its been like it for 2 years (long rebuild).
sway
