  • Dot Guests: 326
Author Topic: Radiator  (Read 2765 times)
Radiator
« on: November 12, 2012, 12:19:59 PM »
Hey everyone.
Any of you have a spare radiator? Just noticed the one in my van is past its used by  :(
Offline hammondo
Re: Radiator
« Reply #1 on: November 19, 2012, 08:40:08 PM »
I have one that was just re-cored and overhauled, cost me a few hundred bucks and now I don't need it with the V8 conversion. PM if interested.
Greg
Offline druid
Re: Radiator
« Reply #2 on: April 20, 2013, 09:39:46 PM »
I just installed a holden jackaroo v6 radiator in mine, fitted well, uses all the space and is nice and thin, bottom brackets were made using a cross bar underneath with sections of inch and a quarter gal pipe joiners (just a straight joiner with 25mm sections cut off the end) for old suspension rubbers(like the front shocky rubbers) inserted into- this makes a neat and strong holder for the radiator pins to slot into. I then welded two bits of 10mm rod at angles on either side of the bonnet catch with the gal pipe bits and rubbers on for the top radiator pins. A new ally radiator cost $270 works well and is cheap to replace and easy too!
